  • Replies 158
Posted Images
hahaha yeah KINDA... except no turbo :P
i gave up on the lawn mower. we decided to get someone to do the lawns on our properties.
mr 32 that sounds good to me mate, bring it past whenever you like, my number is 0422 299 414.. give me a buzz and we'll organise a time that suits you.
ive kind've tuned it, but now when it turns off after the tank runs out it doesnt turn back on unless i give it a break.. is that normal?
it still runs hella rich though.
Nopers.. should be able to start it straight away. If anything, it should be EASIER to start than when it's cold.
I'd guess that your overfuelling is flooding it when it switches off? Needs to be leaned out in any case from what you describe.
ok just got back from 3 hardwares and a plumming suply store and i couldnt fin pvc anywhere near the size of my buggy rims. so it looks like i will have to duck tapping over the rubber. any other ideas would be good.
and is just the rear tyres or do you change all?
thanks mr 32
thanks mr 32
try bunnings warehouse on milperra rd.
ive got some 65mm pvc at my place that i use.
thats what i did before i got pvc.
did you try bunnings warehouse plumbing section?
theyve got 1m lengths of different sizes.. i might go buy some more in a different size to see if i can get a better fit.
yeh i went down to bunnings before but i dont know what section i was in, that place is so big now.
thsts a good idea the tighter the fit the better you dont want them to come off mid slide
Edited by mr 32
hehehe!!
Oh... If it's pouring down with rain tomorrow, obviously this will be off. The courts are outside. Otherwise, it's looking good for tomorrow! =-D
You can use www.travelmate.com.au to map from your house to Abott Road in Curl Curl. Use the map-maker option. =-]
Buggy tyres... sometimes it's best to buy PVC that is a fraction SMALLER than the tyre, then squeeze the tyre inside the PVC (while it's still on the rim)
If you want to mount directly to the rim, use electrical tape and wrap the rim until you can just *barely* squeeze the PVC on. Keep the tape tight all the time, and count how many complete revolutions you do... this makes it quicker for the proceeding rims.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
