Gday guys
I have a few questions bout r32s
in particular how hard is a rb20det swap into a na r32. will it just plug straight up to the standard loom or am i gonna have to buy a det loom to go with the engine?
are the handbrake cable setups any different between turbo and non turbo?
does the r32 turbo dash have any differences in comparison to the non turbo? ie boost guage in the dash cluster ect.
any help is appreciated guys
James
https://www.sau.com.au/forums/topic/104502-r32-questions/
Do the smart thing and go straight to the RB25 or even an RB30 if you have the money. unless you have an RB20 already then sure it's the best option
Only my 2c anyways :)
I Think he was very specific with saying a rb20 ,
The Complyer isnt going to like finding a rb30/25 in there, and i rather not see the car writen off in compliance , :P
So your 2c is noted and dissmissed.
`josh
Edited by avalonea
https://www.sau.com.au/forums/topic/104502-r32-questions/#findComment-1925300
Gday guys
James
I would say ( speaking off the top of my head so to speak) that the swap would be easy as long as the NA body has the holes there for cooler, if your going to use a stock set up.
The loom might be a little different, you got a AFM on both cars, oil pressure gauge/sender on the turbo model (not sure if the NA;s have a oil pressure gauge) as well as the boost gauge, as for engine I would say that the differance would be minimal & there are people out there who could do the few sensors for a minimal fee.
I would just go with the NA Dash & run a dash mount boost gauge in a cup...
Just a idea correct me if I am wrong....
https://www.sau.com.au/forums/topic/104502-r32-questions/#findComment-1925456
  • 1 month later...
my R32 used to be a auto gts4 non turbo, an now its a full converted gtst, the only bad thing is that its still 4 stud, im pretty sure u can use the same loom but it has to be modified a little.
another thing i have all thises bloddy wires under my seat that have plugs on em an arnt hooked up to any thing wat are they for? an nother one thats located under the passenger front seat a little black box with wires going into it an a small braided hose commoing out of it wat the hell?
https://www.sau.com.au/forums/topic/104502-r32-questions/#findComment-1999090
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
