here we go price is 150
we need to pick a date and we need 20 car to make the minimum, there is a 30 car maximum but really we only want 20.
im thinking
sunday march 16th..(really up to when we can book it, this will be discused at the bbq on sunday bobin heads) this is a full skid pan wet day with three instructors (instruction will be minimal and basically we will be haveing a drift corse set up)
all liability is taken care through of and i think we should make this a club event
pete
  • Replies 170
this is what i recived back
Hi Peter,
Thanks for the added information re your planned day.
I have the following to offer your members.
* Minimum of 20 cars to be charged.
* Maximum of 30 cars allowed on the day. (to max your drive time)
* Three instructors at the agreed discounted introductory price.
* $149.00 per driver.
* In car training and operating layout etc provided inc all insurances.
When were you looking to run the day? Weekday or weekend?
Peter, I hope this meets with your approval, call me if you have further
questions.
Cheers
Aaron McGill
sounds good, we will work it out on suday
the bbq will be at this day and should make a great site with 20+ skylines carving up the courses set out
when the date is finalised you will have to be quick cause i have already filled 6 positions (on a 5 minute callaround) of the 20
should be a tops day and i have half a chub already
yea baby
pete
wet skidpan is very easy on tyre (my gtr is in 2wd all day for it)
oz you cant go around a track all your life you have to spin of in the went everynow and again
looks like ill have to turn to the dark side to find the numbers hey
it will happen not overnight but it will happen
i am very interested, as long as the course is designed more for drift, being in the wet sounds good too so it means i dont have to change tyres,lol.
how bout more on a saturday? just a suggestion
com'on guys, let those skylines wag there tales a bit!
find a day when you get 2 hours of driving for 150 bux
anyone who thinks this is expensive should think about how long 2 hours of arse out action is (with minimal tyre wear)
thats
75bux per hour
37.5 per 30 mins
1.25 per minute
(note that is better value than a return ticket to central from bankstow)
(note Moto concept charge 120(on average) for 1 hour of track time)
most likely you will get more like 3 hours cause there is only 20 people
note i only have 5 places left
and naturally there is beers at the pub in the evening
pete
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
