  • Replies 170
Are there spaces left? What's the go if two people want to share one car? Does Mr. McGill frown upon this? I take it you also don't have any problem with non-'lines carving up the concrete? :P
EDIT: Damn, I see I'm now on the second page, and it seems to be full. Anyway, if I'm wrong, please let me know!
Tex
hey all i am pretty new to these forums and to import ownership in general.
How would i go about getting in to just watch and maybe meet a few of you guys in person?
I am interested in getting together with other people who own skylines and this seems like a good opportunity.
Originally posted by Duncan
The buick dorifts?
Sure, don't see why it wouldn't. It's RWD, has a stack of power, and a nice tight limmie - why not? ;) It'd be a real challenge to keep on track though, when 2 tonnes breaks traction, it tends to want to go its own way. I've tested it. :)
Originally posted by red900ss
4 tonnes of Detroit steel floating on marshmallow suspension and cross plys...you don't expect it to handle do you?? :P
Hehe Dino, it's a more conservative 2 tonnes (as above), and it runs radials now - but still, NO. :D:)
As much as I'd love to try the Riv out on the 'pan, it may not be avialable at that time - hopefully it'll be in getting treated to a full respray, and other resto work. I was intending to bring Daddy's BMW.
Anyway, see you all there as a spectator, I imagine. :)
Tex
Thanx for the pm pete, havn't been online for while. The Teins are up to the challenge, and the tyres are bald with the belts comin thru big time (your specifications pete?):P Just hope the clutch holds up till then.
Despite the the objections of a few ppl, i think the skid pan is a great place to learn to drift and learn car control. Hell of a lot safer than on the streets, way too many close calls lately.:eek:
Hi Peter,
Finally I have confirmation from Eastern Creek on the April 6th day for you,
the day is on!
I have attached a booking form that ALL drivers MUST fill out & return to
our office or they will not get a start.
No need to fill in the credit card area as I believe you have taken
depsoits?
We will require 50% deposit for all drivers ASAP as Eastern Creek require
full payment prior to confirming booking. I have done this to secure your
date.
I will have 1 instructor on hand to assist with the control and safety
during the program.
We shall begin at 9.00a.m SHARP and conclude as per Eastern Creeks booking
rules at 5.00p.m.
I'm sure your guys are looking forward to a fun day and that is what this
venue delivers, believe me!
Cheers for now
Aaron M
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
