that will work well .... kinda on the laggier side with the .81 with a big kic in the pants comming on.... from what i am led to believe rear A/R is determined by inlet and engine capacity to be able to spool up at different times or give more HP depending on the A/r rating...
a .9 would give more hp but spool up much slower
a .7 would spool much quicker but less peak hp
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1924701
smaller rear exhaust housing will allow much faster spool up, being a relatively large turbo. My suggestion is to go with a IHI/Apexi AX6 turbo, im running one on my 33 RB27DET and its awesome, spools up early full boost easily by 4 or less and cranks till 9,000rpm or more its a fun turbo to have and u wouldnt regret it, but same thing applies, a smaller rear exhaust housing and itl b crazy..mines larger but i got heaps of engine work
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1924712
My engine currently has a HKS 2835 pro s with a tomei 270 procams and a full bottom end, so I figure I've got the hardware, may as well get a turbo to match it. The hks t04z apparently also comes ian 0.61 housing, does anyone have an idea on start spool rpm and full boost rpm? What hp is a Rx6 rated for?
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1924821
We have a fully built RB25/TO4-Z (HKS) combo due for completion very soon. Engine is done just waiting on cams and injectors to arrive from the land of the rising sun. We have gone with a 0.81 rear housing as the owner is a bit of a power junkie and top-end punch is what he's after. Will keep you posted with our results. The old engine had a GT3040 (garrett) hanging off the side of it.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1925026
My engine with a tune from japan currenlty has a rev limit of approx 8,000rpm, so I'm hoping that should widen the power band a bit. I've already got solid lifters and valve springs so I can't see why this can't be extened another 500 rpm or so. DiRTgarage I'd be very keen to see how that car performs, if you could keep us psoted that would be tops.
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1925249
Yeah ookami, more than happy to keep ya in the loop. Will let ya know how it comes up.
https://www.sau.com.au/forums/topic/104554-t04z-on-a-rb25/#findComment-1925320
  • 3 weeks later...
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
