  • Replies 48
I cant believe how full of "it" some people are!
AND... I cant believe what I am reading!
There is nothing wrong with and never will be anything wrong with modding an "ageing" car and anyone who says that it is a money pit or a time sink is kidding themselves!
eg:
*R31 Aus spec 4 door average purchase price $3000 - $5000 for a good one.
*R32 Gtst Import - $10000 - $16000 for a good one.
*R33 Gtst Import - $16000 - $21000 for a good one.
*R34 GTT Import - $24000 - $30000 for a good one.
Consider those prices as a stock car purchase (no mods) now...
I know R31's and if anyone wants to argue that point PLEASE DO!
A good R31 RB25DET conversion can be done for under $7000 I know because I did one!
As for the brakes and suspension - The brakes dont need major upgrading unless the car is going to see track every now and then just a good set of High temp pads and slotted rotors is enough plus the obvious things like new fluid, wheel bearings and mabye a caliper rebuild, all up - under $1000.
Suspension - Bushes $500 for a full set of urathanes - Fitted, Lowered springs $150 an end and shocks $200 an end.
As for engineering ($600 at the most) - you shouldnt have problem passing it with those mods as long as nothing has been done "bodgy" and the car is road worthy.... Once again I know because I have done it!
All up if the cars exterior is in good condition which isnt rare you shouldnt need to do much else to it apart from maby service or rebuild the diff - $750.
SO - For uner $14000 you will have a VERY nice R31 with ALOT of sleeper apeal and it will be great to drive (and it will upset alot of V8 boys from the lights).
Where as if you buy a later model like a 32 and put an RB25DET in it you will have already spent at least $17000 buying the car and front cut.
So Gus If you want to do it then BLOODY WELL DO IT!
People said that I was an idiot for building my car but look at what it is today and the benifit of it all is that not every joe and his dog has a modified 31 (unlike certain other Skyline models).
Oh and Gus - If you need help with any Parts or work at all let me know cos I can get anything for very cheap (which means it will all be cheaper again) and there is nothing I cant do to a 31.
There Ive said my piece....Now i sit back and wait for the fall out.
Yayyyyyyy!! congrats Gus!!
Getting your first car is the best feeling ever
Yes, it is a Box R31 but hey, its all mine thanks to my brother and his generosity. it's a stock, auto,  white executive, with one flat tyre.
generosity of your brother? is he giving it to you?! :P
eg:
Shut up mick.
Anyways I forgot to mention gus young lad, I will give you a hand with any work you need help with!
Oh and R31 coupes are cooler so lets weld the back doors! :lol:
Hey Gus, i've got plenty of spare parts if you need any to borrow to get over rego... Just ask Bluprint/Mark about my stock :mellow: I'm in tuggeranong as well, from the sounds of it you are as well.
And... Go all out on mods, don't buy cheap shit here and there and plan a bigger upgrade later. Just get the top range stuff and regret it later.
Edited by StinkyPoo
yeah stinkypoo i see you on R31 club, your silo is nice.
at the moment, ive gotta get rego check and see what needs doing with what, then do myself a little write up of my finances and stuff, see if i wana put some money into it and have me a nice first car, or if i wana save my money and go for a really nice car by the end of the year!
and yes shell he did give it to me :P
eg:
HA! remind me again why you want to up-grade???
pfff, as if weld doors to make it look like a coupe, 4door AUS spec is where its at -i sold my gt passage so i could go aus again!
good stuff gus, dont let anyone tell you its not worth doing up, and btw, 300 000kms on a RB30 engine is NOTHING. u got at least unuther 200 000, probly more.
-Tom
Edited by kossak
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
