  • Replies 64
lol i dont speed we dont all speed. I havnt had a fine in my life and thats not just because i havnt been caught. Its called self controll and patience speed and get caught we dont want to hear about it.
DAMN! I am not sure that you should actually be allowed to own a Skyline :rolleyes:
meh.. cops suck.. up here about 12 months ago i had a copper try book me for doin 105 in a 80 zone.. when the stretch of road that we were on was actualy a hundred zone.. funny enough the coppa was pritty stuborn and was 'Positive' it was an 80 zone
as for 114 in an 80 zone.. meh cop it on the chin apply for work license
as for those pricks changing the speed limit.. i wish they'd stop doin that make ya think sometimes there doin it just to raise revenue in that area
i put it to you that your full of shit
if you've never ever done over the speed limit.. you dont own a skyline or you got some crazy f*kn bitch in the passenger seat smashing you with a baseball bat ever time you do more than 1k over the speed limit
or your one of those annoying pricks that sits on 75 in a 100 zone 'to conserve fuel' that ends up having cars back up 500 meters and YOU DONT WANT TO LET US PAST
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
