Hey guys,
Has anyone got any ideas of good license plates.
* Something original
* Nothing too derogatory
* and nothing slezzy ... no offence to people who have em but i can't stand the ****4U........type of license plates
at the moment i don't wanna pay $400 per year for the full custom types
the following format is good
AAA12A (3 letters, 2 numbers, 1 letter)
or
AA12AA (2 letters, 2 numbers, 2 letters)
i've got a r34 skyline so a license plate that relates to the car would be good
Sorry guys im just not creative enough.... :)
cheers
Mark
https://www.sau.com.au/forums/topic/104624-license-plates/
34 SEX
DSTRBD
34 PSI
just noticed you didnt want personalised.still good plates though.
GUN-34R or GUN-34T
MY-34-GT
WRX-10L (laughing out loud at wrx's)
BY-81-4D (bye bye ford)
RE-34-AL
DB-34-ST
Edited by RSTME
https://www.sau.com.au/forums/topic/104624-license-plates/#findComment-1925583
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
