HO.00.MO
PE.33.NS
WH.00.RE
AN.44.AL
HEA.34D
hahahaha jus kiddding... get your nickname or sumthing like i did... had custom plates on my old car and they got sold with the old girl... now ive got my nickname that ill prob have for years :O
TU-34-FF
RI-34-CE
CH-34-TR
XH-34-TX
HOT-34T
SXY-34T
NSM-034
XM-34-NX
AP-34-LN
DF-34-TU
CR-34-TD
These are all available and according to RTA site its $30 ordering fee + $90 a year for these plates
nice input mate!!
really appreciate the suggestions guys. love the use of 34 as E-A.
top job mate!!
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
