Hey Guys,
Ive been looking at buying a 32 for the past nine months. One came to my attention and have been eagerly following it for the last week or so. He sent me across the compression/leakdown test and here are the results:
1-134psi/20%, 2-127psi/20%, 3-149psi/10%, 4-133psi/28%, 5-146psi/10%, 6-136psi/28% .
From what i have read the compression should be about the same across the board. What do these mean to you? Would like to know if it is screwie before i throw down the cash.
Cheers.
https://www.sau.com.au/forums/topic/104634-r32-gtst-compression-test/
Could the test been done incorrect? Also how is the test done?
The test is done by connecting a pressure gauge to the spark plug hole on each cylinder. The engine is then turned over and the maximum pressure in each cylinder will be recorded on the gauge. The more wear in things like piston rings, valve stem oil seals, cylinder bore etc. the more air will leak from the cylinder giving a lower pressure in the cylinder.
It is possible to do the test wrong, you have to have the throttle fully open and the engine oil up to working temperature to get the best readings.
Hey Guys,
Cheers.
Compression test are too easily affected by outside factors, so I rely on the leak down test results.
Leak down around 20% (or less ) is OK for 12+ year old car. The 28% on 2 cylinders is a bit more than I would be happy with.
:P cheers ;)
compression is piss poor, spec is 175psi.
there is alot of varience across the board there, engine might not be in good condition.
Actually according to the R32 manual, the RB20DET's factory value is 170psi and actual limit value is 128psi. The allowed variance between cylinders is 14.2psi....
I doubt anyone with a 15 year old engine is going to get 170psi.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
