Hey Guys,
Ive been looking at buying a 32 for the past nine months. One came to my attention and have been eagerly following it for the last week or so. He sent me across the compression/leakdown test and here are the results:
1-134psi/20%, 2-127psi/20%, 3-149psi/10%, 4-133psi/28%, 5-146psi/10%, 6-136psi/28% .
From what i have read the compression should be about the same across the board. What do these mean to you? Would like to know if it is screwie before i throw down the cash.
Cheers.
https://www.sau.com.au/forums/topic/104634-r32-gtst-compression-test/
Could the test been done incorrect? Also how is the test done?
The test is done by connecting a pressure gauge to the spark plug hole on each cylinder. The engine is then turned over and the maximum pressure in each cylinder will be recorded on the gauge. The more wear in things like piston rings, valve stem oil seals, cylinder bore etc. the more air will leak from the cylinder giving a lower pressure in the cylinder.
It is possible to do the test wrong, you have to have the throttle fully open and the engine oil up to working temperature to get the best readings.
Hey Guys,
Cheers.
Compression test are too easily affected by outside factors, so I rely on the leak down test results.
Leak down around 20% (or less ) is OK for 12+ year old car. The 28% on 2 cylinders is a bit more than I would be happy with.
:P cheers ;)
compression is piss poor, spec is 175psi.
there is alot of varience across the board there, engine might not be in good condition.
Actually according to the R32 manual, the RB20DET's factory value is 170psi and actual limit value is 128psi. The allowed variance between cylinders is 14.2psi....
I doubt anyone with a 15 year old engine is going to get 170psi.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
