didnt hav a sign but yeh lost 3points ... on the rta website it says the only time ur allowed to do a u turn is if it has a sign sayng "u-turn permitted" that suks i jus got confused coz i thought u could do a u-turn at the lights if their were no signs up sayng u couldnt oh well guess i thought wrong. thanx for the replys
oh one last thng does ne1 know how many points u lose for going thru a red light camera?
cheers
https://www.sau.com.au/forums/topic/104652-demerit-points/#findComment-1928202
no the red light ques was for my bf.
firstly theres no need to make stupid remarks
and no i didnt run a red light to make a u-turn.
gee cant get simple answers.
the u-turn my bf done as there was a big meet up round bankstown area (sydney)
cops turned up we all seperated n lost all the cars then we done the u-turn n the cops were hiding in the dark therefore wanted to know how many demerit points.
so if you wanna be smart about it dont bother
https://www.sau.com.au/forums/topic/104652-demerit-points/#findComment-1931401
yeah, in vic its allowed. went up to nsw...busted, they let us off for showing we were from melb and didnt know the differ laws until just then. not all cops are bad!...?
next time it happens, throw $2 at their feet and yipee, at your command. :(
https://www.sau.com.au/forums/topic/104652-demerit-points/#findComment-1933197
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
