nugget400hp Posted February 6, 2006 Share Posted February 6, 2006 G'day guys, ive just baught an r32 gtr with a fresh rebuild, apexi full adjustable computer, full 3.5" hks exhaust with dumps, pods, nismo fuel reg a blitc ebc. before the computer and rebuild it made 226rwkw on 14psi. Just wondering what times ppl have run with similar setups down the qaurter. it also had a brand new exedy hi performance clutch. thanks Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/ Share on other sites More sharing options...
Swiper the Fox Posted February 6, 2006 Share Posted February 6, 2006 G'day guys, ive just baught an r32 gtr with a fresh rebuild, apexi full adjustable computer, full 3.5" hks exhaust with dumps, pods, nismo fuel reg a blitc ebc.before the computer and rebuild it made 226rwkw on 14psi. Just wondering what times ppl have run with similar setups down the qaurter. it also had a brand new exedy hi performance clutch. thanks <{POST_SNAPBACK}> Mid to low 12's should be achieveable. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926448 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 (edited) edited for the people who were offended. Edited February 6, 2006 by nugget400hp Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926491 Share on other sites More sharing options...
TTT Posted February 6, 2006 Share Posted February 6, 2006 Hey nugget - how old are you? Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926508 Share on other sites More sharing options...
PHATR32 Posted February 6, 2006 Share Posted February 6, 2006 man you shouldnt have added the fishing part to your storry........ Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926539 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 Hey nugget - how old are you? <{POST_SNAPBACK}> im 17 mate, why. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926550 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 also, what psi can i push through standard turbos Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926551 Share on other sites More sharing options...
TTT Posted February 6, 2006 Share Posted February 6, 2006 just wondering is all. stock GTR turbo's have the same issue as gtst turbo's. ceramic exahust wheels. I think 1 bar boost is what most people are willing to do. more than that, they are no efficient,... and even at that level they could have exhaust wheel issues. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926585 Share on other sites More sharing options...
Tommyk Posted February 6, 2006 Share Posted February 6, 2006 1 bar max Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926616 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 how much psi is one bar? sorry guys, im from a vl turbo background lol. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926617 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 what will n1 turbos set me back roughly? do they bolt up to stock dumps and exhaust manifold? Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926625 Share on other sites More sharing options...
TTT Posted February 6, 2006 Share Posted February 6, 2006 1 bar = 14.7 psi. n1's are pretty expensive from what I've seen... over $2K?? they seem to be good for about 1.2 bar (17-18psi) Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926693 Share on other sites More sharing options...
nugget400hp Posted February 6, 2006 Author Share Posted February 6, 2006 cheers. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1926844 Share on other sites More sharing options...
rev210 Posted February 7, 2006 Share Posted February 7, 2006 Hi Nugget. The N1's are going to need a few other things to make them work. Injectors / Ecu / fuel pump / big clutch etc... The thing to do is to sit down and try and work out what sort of stuff you want to do with your car. Take your time doing it. Then progressively get everything that matches the desired purpose. You end up with what you want (or think you want) in such a way as to save you money and to a greater extent a better packaged car overall. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1931392 Share on other sites More sharing options...
nugget400hp Posted February 12, 2006 Author Share Posted February 12, 2006 thanks mate, i have ecu fuel pump and clutch so ill just be after some turbos and injectors. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1944013 Share on other sites More sharing options...
MrBlonde Posted February 13, 2006 Share Posted February 13, 2006 1 bar = 14.7 psi.n1's are pretty expensive from what I've seen... over $2K?? they seem to be good for about 1.2 bar (17-18psi) <{POST_SNAPBACK}> No, 1 bar = 14.5 psi. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1946756 Share on other sites More sharing options...
raddavey Posted March 1, 2006 Share Posted March 1, 2006 No 1 bar=14.7psi or 101.3KPA gauge. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1988358 Share on other sites More sharing options...
chops Posted March 2, 2006 Share Posted March 2, 2006 1 bar = 14.5037738 pounds per square inch Atmospheric pressure is 14.7psi or 760.0 mm Hg; 760.0 torr; 101.3 kPa; 1.013 bar. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1989745 Share on other sites More sharing options...
ferni Posted March 2, 2006 Share Posted March 2, 2006 Hi Nugget.The N1's are going to need a few other things to make them work. Injectors / Ecu / fuel pump / big clutch etc... The thing to do is to sit down and try and work out what sort of stuff you want to do with your car. Take your time doing it. Then progressively get everything that matches the desired purpose. You end up with what you want (or think you want) in such a way as to save you money and to a greater extent a better packaged car overall. With N1's you wouldn't really need injectors or fuel pump. Good clutch and ECU for sure. Link to comment https://www.sau.com.au/forums/topic/104682-what-times-should-i-do/#findComment-1990170 Share on other sites More sharing options...
