Just wondering if when you take the restrictors out of a R32 GTR how safe it makes it. Do you get boost spikes or it stay under 15psi like I have heard?? Was going to put an electronic boost controller in but I would just leave it at 15psi anyway. Please people with experience with this wb.
Cheers
https://www.sau.com.au/forums/topic/104712-taking-restictors-out-of-gtr/
Cheers
Adam, you can do it this way quite safely. However...
The results aren't as predicatable as you may have been led to believe. The results people get vary from car to car. A better bet is to spend all of $80 or $90 on a Turbosmart bleed valve. That way you can set exactly the boost you want (up to a point).
A bleed valve will not always give a straight line boost response. Mine (by way of an example) carries a little more boost lower in the rev range than at the upper end. A properly set up EBC will give you a flat line all the way across the engine rpm - up to the point where either the turbo can't move sufficient air (& the boost will drop off) or the waste gate can't move sufficient air(&the boost will climb).
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
