Yes ss is worth it
i got my polish ss 3 years ago
a mate has mild steal 2 years old and it looks like it need replacing again and dollar value is about 40% difference i think
james
SS - not worth the money at all IMO.
Its horridly over priced for no gain what so ever.
Mild is a little quieter too incabin i believe. But im not totally sure there.
Im getting my twin 2.75" system made in Mild without a doubt
Mild steel will outlast the life of your ownership like most younger line owners.
I plan to have my car at least 5 years, probably a lot longer
Mild steel will last that time no problem for me and they dont rust like people say if you look after it properly
Remember a turbo makes a lot more heat :D
hi guys i was wondering if a stainless steel exhaust is worth pay the few extra hundred bux for?
Also does anyone recoment any place in syd for me to get mine done?
SS would be worth it yes if your keeping car for awhile. i Know a guy in smithfield he does his on mandrel bends etc..his got all the machinery there...ill get the number and you can call him
yeh i can't see the point... parents owned a falcon from new (back in 1983) an dit didn't need a new exhaust till 1999, and it didn't really even need one then, i think a muffler got a hole in it from a rock...
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
    • Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
    • It won't be this - not while it's driving, anyway.
