The wraps are finally coming off my project GTR. It has nearly $22K worth of rebuild value in the past few months, and has ZERO kilometres on the new engine. The RB26DETT has been built ( by a GTR specialist) with forged pistons to handle much higher output than that which I will run it at. The turbos have been rebuilt and high flowed, with bigger dump pipes. $5K worth of Dupont 'Jag Green' respray with an amazing orange and gold pearl fleck throughout. And brand new Simmons FR18's with new tread all round have just been fitted. Car is currently having lip spoiler and rear wing ( both stock GTR) sprayed and fitted. You can either but a truly unique, robust and breathtaking example such as this, or you can save several thousand, compromise on quality, and soon regret the fact. This car is an absolutely must see for anyone genuinely interested in a special GTR, and willing to spend a few more dollars to get the car that they want. An ideal GTR for someone wanting to build a big HP single conversion.
I will consider trades to the value of $15K, but only if price expectation is reasonable.
ASKING PRICE $26990.
cheers,
Jeremy
Edited by R34_T88_Widebody
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
