  • 5 years later...
  • Replies 97
Posted Images
Hey guys. I heard there was a GTR at the drags on the weekend that did a 10.6 or something. Who was it?? XRATED?
Does anyone know how Matt is going with his Blue 32 GTR???
reply is a bit late... but yeeeer, that was mee... ha ha ha- ah the good old days. :nyaanyaa:
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5917166
drunken thread dig of the decade!
Yep.. ha ha ah, just kind of stumbled over it. :cheers:
Think it was just under 400kw and possibly had a gearset but cant remember as that was a long long time ago......
Whats new with XRATED....?
396rwkw and a ppg dogbox- ooh and a lill hit of gas.
Nothing yet... the damn gts-t is taking up all my time atm. I'll be striping xrated down in september.
Cheers
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5918191
i think i have a pic from 06 at the drags if i remember correct i think it was the day you did a 10 ill try & find it thumbsup.gif
I tried to post up some pic's last night, but I can't seem to upload anything atm...\
On another note, if anyone has any pic or vid's please post em up. I lost a large chunk of my old footage and pic's on a stolen laptop years ago.
Cheers
Justin
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5921865
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
