Folks,
I have a HKS mechanical Oil Temp gauge I want to install... where would you recommend it be placed...the sump? I would have considered putting the sender into my Spin On Adaptor but I have oil pressure already there, and its actually far to big to fit into it.
So this leads me to the next issue of drilling the sump to fit it... can I remove the sump off the motor without removing the engine or crossmember?
Thanks alot in advance!
JK
https://www.sau.com.au/forums/topic/104783-rb20-sump-removal-for-temp-probe/
Have you considered getting a line made from somewhere like pirtek or enzed to fit the adapter and then remote mounting the temp sensor? It wouldn't be much different than mounting the sensor in a remote mount filter.
It would also be a lot easier than having to remove the entire sump and welding in a fitting.
On a side note: Aren't the pressure sensors usually the big ones? My temp sender is tiny in comparison to my pressure sender.
My pressure sensor is built into the guage (being mechanical) - so its only a very small oil line that has to go into the spinon adaptor. The oil temp sensor is quite big - about 12mm in diametre!
JK
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
