Hey guys, I saw this boost controller on the Hikari website and a few others, yet i havent found any other info on them in regards to how they preform compared to the way more expensive Jap brands. FYI Hikari are sellin them for 320. Thats a fully electronic Dual stage boost controller that has in cabin control. Seems to good to be true. It also looks quite nice and looks like it would fit snug in the position of the ash tray (which is good as im not a smoker).
If anyone can shed any light on this product whether its reliable and how it preforms, etc, it would be greatly appreciated.
Thanks
http://www.hikariperformance.com/new_electronics.htm
(scroll rite to the bottom)
https://www.sau.com.au/forums/topic/10481-hybrid-electronic-boost-controller/
I was told but am not 100%sure that they are like a electronic version of the turbosmart type 2 stage bleed valve setup, so they are not as accurate as controlling boost like good elec ones they just give you control in the cabin.
They are nothing like the TS twin stage they do run a micro processor
seen in two cars now work well but you need to have a map sensor of some type ..... like you need to tap into say the std dash map on r32/33 but on somthing like a s13 you'll need to hunt a map sensor down
I sent power digger an email.
Heres what i sent:
Hi
I wondering if you could supply me with as much info as u can on the Hybrid fully electronic boost controller. How does it work through the microprocessor? Is it like an AVCR, or not as indepth and efficient. Will it hold high boost levels, and will the boost levels spike due to it being a bleed valve type boost controller. Im very serious on buying one, just want more info before i make my decision.
Thanks
Dean
And heres his reply
thanks for your interest it has a micro built in and by sensing the boost signal the micro calculate the right boost amount
in other words it try to bring the boost up to preset level as soon as possible and soon after it reaches the preset boost it regulated it
never over shoot
beside it is not a bleed type valve it is a proper 9 bar solenoid valve that uses in many other Japanese boost controller
Thanks
  • 3 weeks later...
Hi all,
I have installed the hybrid boost controller. I have to say it was the easiest ebc install(just three wires, the same three that run to the factory boost reciever in the engine bay) i have ever done!!
Very easy to tune, just set the dials for hi/low boost.
On the road it holds boost and at 20psi is only only slightly shaking the needle on the boost gauge (not more than half a psi either way.
As for brining boost on earlier I noticed a little differance
install 9/10
tunability 10/10
boost holding 8/10 (twin solonoid would have been better)
Appearance 4/10 (only one blue led and no screen as per avcr)
All in all not bad for $325 delivered
  • 3 weeks later...
Hi There,
I also noticed the "powerdigger" at UAS (for $380).
Seems like a really good buy.
Quick question for those who have installed it.
- Does the car fill "jerky" when on full boost as some one mentioned that is was changing half a psi up and down (at 20 psi).
I am only planing to run 12 psi, will I notice it? How smooth is it under boost?
- when it comes to installing it, where is the "map sensor" or "boost sensoe" what ever it is called... I should have no problems installing it just need to find that boost sensor (for an R33 gts-t)
Thanks for your answers.
Regards
Rob
Hi Rob the car is not jerky when on boost, even though the boost needle is moving. When you get the intstructions it has a picture of the boost sensor and how to wire it all up. The boost sensor should be on the left hand side of the firewall. easy to spot if you know what your looking for.:)
If anyone else has installed one please write your comments, as I wonder if it is any differant on a smaller tubo, unlike mine which has a fair bit of lag.????
Ps go to hikari they are $325 delivered
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
