Hey guys i bought a power fc for my manual R33 s2 and took it to the mechanic to tune it. Since the time we fitted the power fc to my car engine check light and exhaust tempreture light is on and wont go off after tuning it too..
What could be the problem?
Any one with the same problem?
https://www.sau.com.au/forums/topic/104863-new-power-fc-on-series-2/
the power fc light is on if sensor is faulty i have 32 with neo i i got rid of all tracton controll shit hense the light is always on ime going through and wiring all sensors back in so no light power fc has sensor check mode where u can see what voltage sensors are doing also if one is outside the paremeter it will set it off as well
any questions on this pm me
have u tried a searcH? this is covered in the unofficial apexi power fc faq (in my signature). the check engine light will stay on if you have the boost kit turned on (and arent using it), disable it. unplug the exhaust temp sensor, its useless, two wires where the catalyic converter is
Strange, do you notice anything else wrong or not working? What is the water temp reported by the hand controller under MONITOR, WATERTEMP ?
Is it 414-N012 or 414-AN012 ? What version is reported by ETC, VERSION
very odd. what was $1000 for exactly? what did they check/do ?
has it been tuned completely or still on stock maps?
does the car drive ok? im assuming this light goes away with stock ecu ?
sounds like your getting ripped.
$1000 is f**ked.
My tuner hit me $300 for a shit tune that I could have done by hitting the keyboard of my laptop with my cock.
anyway, yeah, dude, read the faqs.. Look at the sensor readout on the powerfc and look for any erroneous values on monitor side of the powerfc..
f**k, I reckon I'd have it fixed in an hour.. I should start my own shop..
I went 2 the best two tuners in melbourne..I dont want to mention the names but what they did say was the power fc was faulty.
They tuned it half way didnt do a full tune...For the stock ecu its fine...
Edited by chzz
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
