Hey guys i bought a power fc for my manual R33 s2 and took it to the mechanic to tune it. Since the time we fitted the power fc to my car engine check light and exhaust tempreture light is on and wont go off after tuning it too..
What could be the problem?
Any one with the same problem?
https://www.sau.com.au/forums/topic/104863-new-power-fc-on-series-2/
the power fc light is on if sensor is faulty i have 32 with neo i i got rid of all tracton controll shit hense the light is always on ime going through and wiring all sensors back in so no light power fc has sensor check mode where u can see what voltage sensors are doing also if one is outside the paremeter it will set it off as well
any questions on this pm me
have u tried a searcH? this is covered in the unofficial apexi power fc faq (in my signature). the check engine light will stay on if you have the boost kit turned on (and arent using it), disable it. unplug the exhaust temp sensor, its useless, two wires where the catalyic converter is
Strange, do you notice anything else wrong or not working? What is the water temp reported by the hand controller under MONITOR, WATERTEMP ?
Is it 414-N012 or 414-AN012 ? What version is reported by ETC, VERSION
very odd. what was $1000 for exactly? what did they check/do ?
has it been tuned completely or still on stock maps?
does the car drive ok? im assuming this light goes away with stock ecu ?
sounds like your getting ripped.
$1000 is f**ked.
My tuner hit me $300 for a shit tune that I could have done by hitting the keyboard of my laptop with my cock.
anyway, yeah, dude, read the faqs.. Look at the sensor readout on the powerfc and look for any erroneous values on monitor side of the powerfc..
f**k, I reckon I'd have it fixed in an hour.. I should start my own shop..
I went 2 the best two tuners in melbourne..I dont want to mention the names but what they did say was the power fc was faulty.
They tuned it half way didnt do a full tune...For the stock ecu its fine...
Edited by chzz
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
