Hey guys i bought a power fc for my manual R33 s2 and took it to the mechanic to tune it. Since the time we fitted the power fc to my car engine check light and exhaust tempreture light is on and wont go off after tuning it too..
What could be the problem?
Any one with the same problem?
https://www.sau.com.au/forums/topic/104863-new-power-fc-on-series-2/
the power fc light is on if sensor is faulty i have 32 with neo i i got rid of all tracton controll shit hense the light is always on ime going through and wiring all sensors back in so no light power fc has sensor check mode where u can see what voltage sensors are doing also if one is outside the paremeter it will set it off as well
any questions on this pm me
have u tried a searcH? this is covered in the unofficial apexi power fc faq (in my signature). the check engine light will stay on if you have the boost kit turned on (and arent using it), disable it. unplug the exhaust temp sensor, its useless, two wires where the catalyic converter is
Strange, do you notice anything else wrong or not working? What is the water temp reported by the hand controller under MONITOR, WATERTEMP ?
Is it 414-N012 or 414-AN012 ? What version is reported by ETC, VERSION
very odd. what was $1000 for exactly? what did they check/do ?
has it been tuned completely or still on stock maps?
does the car drive ok? im assuming this light goes away with stock ecu ?
sounds like your getting ripped.
$1000 is f**ked.
My tuner hit me $300 for a shit tune that I could have done by hitting the keyboard of my laptop with my cock.
anyway, yeah, dude, read the faqs.. Look at the sensor readout on the powerfc and look for any erroneous values on monitor side of the powerfc..
f**k, I reckon I'd have it fixed in an hour.. I should start my own shop..
I went 2 the best two tuners in melbourne..I dont want to mention the names but what they did say was the power fc was faulty.
They tuned it half way didnt do a full tune...For the stock ecu its fine...
Edited by chzz
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
