hey thanks for that, i will have to look more closely at that the next time its, apart which will be soon.
btw great times, from you car & driving!
cheers Russ
Cheers Russ, the times are in the car....im still a n00b at this drag racing stuff. My career as a driver is 5 meetings old !. Slowly getting a handle on it though. High end drag racing is not as easy as some make out to be.
From all accounts your an awesome steerer, love to see you in action punting one of Nissan's finest to the max.
When Tomi comes back from Japan ill see if i can get some clearer info on the transfer case for you.
Edited by DiRTgarage
  • Replies 78
thanks mate, yeah steering them isnt as easy when you have so much under your right foot is it!
thanks for any info on transfer cases too, will be very keen to do something there!
i am not exactly too hot at the drags either, i tend to side step it too much! :P and hey bingo the worlds worst 60 footers. i have never been near a 1.6 60 footer.!
hey mik was the exige the one that had the tape on the back corner?
i remember the silver rexy hatchy too! was my favorite round and cant wait to get back there.
cheers Russ
thanks mate, thanks for any info on transfer cases too, will be very keen to do something there!
No problem, Ben a Racepace does a similar mods (see previous posts) spoke to him on the phone at length and really knows his stuff.
Stacey has done a 1.68 60' before with less power than we have now on Federal road tyres....awesome work. My best is a 1.49...but using the M/T street drag radials....cheating in my eyes as they are almost a slick really, god only knows how they are DOT rated !
My Transfer case will be getting upgraded by Racepace in the next couple of months, from what Ben tells me he does a 10 plate upgrade. Will wait and see the results.
would be great to hear your results! when you get a chance.
it seems that my 4wd is still functioning reasonably well, as when it is not (as has happened for half a rally :P ) it goes into wheel spin when the power comes on in third !! hehe but it would be great if the 4wd reaction was quicker with harder bite.
i do have a 4wd controller that duncan sold me which has helped considerably. and also have a torque split controller fitted as well but i have never used it in racing or drags as it appears to get some driveline wind up when you get wheel spin, which was a bit concerning.
cheers Russ
:P 1.49 must feel like your sternum is going to go out your back!!
great work!!
paul,
What is your best 60' using real street tyres?
I remember doing low 1.6s on the federals at Drag Wombat...ill dig up the slips.
always driving around the water...i.e no burnout
cops arse :P They're DOT rated because they've passed the relevant testing and have sidewalls and stickers (when new) to show this.
They're not a cross-ply, they're not a slick and you can run them on the road!
Cheating? How's 2.6l, TWO turbos (showoff) and 4WD for cheating?!?! :O
Adrian
cops arse :)  They're DOT rated because they've passed the relevant testing and have sidewalls and stickers (when new) to show this.
Have you tried high speed cornering with them...or even low speed for that matter...wrinkle wall slicks would be safer. How they are classified a street tyre is beyond me....but in saying that...while they are ill still use them.
cheers Russ
Can't remember if the Exige had tape on it, there were two ornage ones there, but Jason's is the one with 'RPM' number plates. He had to retire because it lost the harmonic balancer doing a burnout before the quater mile run.
He will be back this year, but I have a feeling he will bring his GT2 this year.
The silver rexy is actually pretty quick, he had a few issues though too...broke the exhaust manifold. He finished the round, but couldn't make much boost.
your not running high PSI in the tyres are you though?
Like 20 or less?
Im sure if you bumped them to 40psi tyre pressure like most road tyres should be at, they might not be "that" bad possibly?
Maybe thats how they passed, even if they are never used that way
Like 20 or less?
good point...14psi isn't great for cornering
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
