Yeah thats because i'm designing it... now i got all my other carbon stuff done i can start working on it...
the airbox will be made in the front right hand side and mine will be open top and seal against my carbon bonnet.. will also be ceremic coated same thing we do to all of our V8 race stuff... helps keep the heat out too.. will post pics as i go along..
i do all my own carbon fibre work mate, as i'm a qualified composite technician.. if you need stuff anything done just give Custom Carbon a call.. details are in my sig
maybe ill get mine remade...
see how different it is.
  • Replies 90
the carbon bit on the bottom (usually black plastic) is off a series 1/2. Series 3 have a larger, deeper lip with brake ducts.
Cool can see the difference now (and the blue on the seats in the first lot of pics). The lip on my car is rooted from the previous owner. Was considering a carbon one, but would prefer the S3 shape.
why is the carbon is such big squares? Can you do it in smaller squares?
carbon is big squares because i wanted something that would draw attention, you will not see another bonnet like it, unless i make another one for someone else ha ha.. yes can do carbon in a smaller weave.. i think your after the standard 3k carbon twill personally i think its boring because everyone has it.. i like to be different..
you sure its a series 3?? it hasn't got the front lip.
series 2 with series 3 headlights...
series 2's have the brake ducts too.... :D just the lip is not as agressive.. glad i dont have one as my driveway has worn the bottom off the series 2 one anyway. series 3 one i wouldn't be able to get in my driveway at all.
Edited by MrVspec
Series 3 lip:
http://picasaweb.google.com/fernii/Racingl...134800658563090
Looks more aggressive than the S1/S2. Also bigger brake ducts. If i had of had a fibre glass one it would of been shattered by now.... avoid fibreglass, orig plastic is the goods, CF is probably in between the 2?
Out of interest - what would one of those carbon front lips cost? what about your bonnet? I assume its full CF not half fibreglass?
the lip is $880 Inc GST they come clear 2-pak'd with UV stable 2pak and bolt straight up..
bonnet hmmm something like that would be around $3500 Inc GST and yes its 100% carbon fibre NO fibreglass also comes clear 2pak'd with UV stable 2pak and bolts straight up perfect.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
