don't know who makes that LSD, but to convert from a 2 way to 1.5 way requires a teardown and replacement of some parts in the cam system. that is one clean diff though. :O
Edited by BronzeMFP
This LSD came ina R33 GTS-t I bought, can you ID it please, and if so are they convertible from 2 way to 1.5 way? It's set up as a 2 way at the moment.
Judging by what is clearly some sort of spring which is part of the internals of the diff centre, that's not Nissan centre or the 'usual' type of clutch pack LSD. Probably some sort of aftermarket LSD and in that case doing any sort of work on it could be 'difficult'.
Someone has e-mailed me to say it looks like a Cusco RS type. In which case I should be able to rotate the pressure rings and convert from 2 way to 1.5 way myself, with no parts needed.
Well if that's what it is and you know what your doing........I did say 'could'.
I pulled the diff out this afternoon and took the LSd out of the casing. i believe it IS a Cusco RS, although there was no makers logo on it. The centre section has two possible ramps, an equal angle ramp set that gives the same preload increase under acceleration and decelleration, which is how it was set up, and a "1.5" way ramp set up, that gives more preload gain on acceleration than on decelleration. I have rebuilt it like tat, hopefully slow corener understeer (push) will have been helped or eliminated, and it should be more of a circuit race diff now, tahn the aggressive drift type it was before. At least it was a cost free excercise, if it helps i will know in what direction to proceed. I fancy an OS Giken LSD, I believe these are fully user adjustable with variable preload and other trickery. has anyone any direct experience with them? Thanks.
  • 1 month later...
Its looks like a cusco RS too me.
Looks identical to mine in my R32.
I think it can be paulled aprt and the casing set up to become a 1 way or a 2 way from memory.
check this link it may help.
http://www.cusco.co.jp/english/e_lsd.html
Edited by RedDrifter
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
