hey everyone,
im in the process of putting together a rb30det. But i dont have a r33 service manual, i only have the rb30 manual. Does anyone happen to know the torque settings to tighten my:
- head bolts to (what sequence aswell if there is one)
- rockercover screws
- camgear bolts -vct and exhaust gears...
-if you guys can help me out it would be much appreciated!
thanks
-Tom
Ummm i think you made an error?  You need to know about an RB25 in the title, then you ask about an RB30 which you have a manual about...
na mate, rb30Det
its got a rb25 head. There for rb25 head torque settings
and it is the turbo head, not the non turbo head...
-Tom
Edited by kossak
hey everyone,
thanks
-Tom
Head bolt torque specs will be on the VRS set you bought.
Rocker cover screws....are you kidding?
Camgear bolts...F.T.
rocker cover screws i assumed didnt really matter, but still, i wannna try n do it rite if i can.
as for the head bolts
wtf is vrs kit? (im a n00b stuggleing to put together a engine) -im assuming it is the headgasket kit??? if it is i got a complete head gasket kit from nissan so no torque setting there. Also what about the intake and zorst manifolds then?
doesnt ne1 here have a 33 workshop manual or at least hav a link to an online 1 (that is free)
-Tom
  • 13 years later...
On 2/8/2006 at 9:02 PM, The Dan said:
Here
Hi All
Firstly , thanks to everyone for the help!
Secondly - am I understanding the process Step 4 ( tightening the head bolts ) sub-step 3 says to loosen to ON-m, so am I understanding correctly that you do 5 passes in the suggested sequence
1st Pass - to 29N-m
2nd Pass to 98N-m
3rd Pass - back everything totally off?
4th Pass - 25-34N-m
5th Pass - 93-103N-m
Did I get that right or am I a complete dickhead??
@the dan Thanks for the image, is that from a FSM kicking around here somewhere?
6 minutes ago, SSSHONKY_V_2 said:
Hi All
1st Pass - to 29N-m
2nd Pass to 98N-m
4th Pass - 25-34N-m
Correct
it is done this way to “bed in” the threads to ensure a more accurate clamp load
OK so, things are progressing well. My torque wrench proved unreliable at low torque settings so was fortunate enough to have a good mate loan me a Sidchrome precision torque wrench , what a beauty of a tool to use!
I did the initial 3 passes , so now they are all loose waiting for the final tightening.
My question is: Who uses the angle measurement tool for the final tightening? I am not adverse to buying one considering they are pretty cheap, or just dummying something up with cardboard and something to hold it in place with.
Is a torque wrench enough, or do you need the angle of the dangle?
4 hours ago, GTSBoy said:
If the spec on the bolts is torque, use torque. if the spec on the bolts is angle, use angle. Accept no substitutes.
Except in the wokshop manual screenshot above where it gives both :p.
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
