I was thinking about making a catch can at home instead of buying one. Most of the catch cans you can buy are quite large and could easily fit 0.5 - 1.0 Litres of oil in them.
For those of you with a catch can, I was wondering how much oil is actually collected/drained from the can, and how often. Please provide your engine type, kms the engine has done and power output to get a gauge on how big I should make the can for my car.
https://www.sau.com.au/forums/topic/104939-catch-can-how-much-oil-is-collected/
For reference I have a stock RB26 (bottom end) - making about 325rwkw's and every time I go out onto the track for a 3 lap sprint I have to drain about 1.5L of oil out of my catch can.
But my car is pretty excessive in this front.
The amount oil coming out will depend on the condition of the motor and the amount of boost your running. As rings wear out they allow more blowby. Raising boost will also create more blowby. for example my RB25 with about 40km with stock boost does not blow out a single drop of oil. Our shop race car s13 sr20 with 1.4 bar boost, blows out about a quart of oil after about 2-3 laps. we had to plumb a drain tube from the bottom of the catchcan to the turbo oil return hose so that we didn't starve the motor of oil.
-Bluefire
Edited by bluefire
In an RB it has more to do with just "worn" rings etc.
SR's and RB's cant be compared in this topic.
RB's have a large problem here even if they are totally healthy in the motor side of things
I'm not concerned with anybody who races their cars. I'm only really interested in daily driver cars and how much a stock or lightly modified RB would blow. Does the average Jo that uses their car for a run to work and back each day with the occasional spriited drive really need an catch can that can hold 1 Litre of oil. I think not.
You should perhaps look into the reason you require a catch can, if you need one then most likely something is leaking, such as the turbo seal as you are getting oil in the intake piping. You may as well just fix the turbo seal rather than making a fix for the oil in the intake for a normal street car if that makes sense.
My car only has 21,00km on it so it doesn't get any really noticable oil blow-by (nor leaking seals), but I want to prevent oil coating my intake piping now and in the future. IMO a catch can would be useful to gauge whether any seals DO start leaking in the future.
I was going to ask this myself. I dont get anywhere near as much as 1 litre but sometimes if i really gas it.. I can get 200mls of oil in the bottle i rigged up. got a oil catch can and im going to run it back to the sump and into the intake as well.
Sydkid told me that any high performance engine needs a catch can. I got away with having one till 220rwkw and he said i shoulda needed one for that much power even...
So yeah now i got a gt3540 running low boost and it does bow oil when i give it heaps.
Edited by Guilt-Toy
I was actually considering using a fuel filter/water trap that diesel engines use (See pic). This can hold about 100mL but you can get bigger ones. Only costs about $35 too
Edited by MearCat
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
