have a r33 s2 turbo for sale just came off my car yesterday.
pics are available in the for sale section. look for the little smiley face and darwin. put it up today. $400 + postage ($30 to sydney normal post from darwin).
hey mate ive got a t3/4 that just came off my r33, i put the turbo on but just as i put it on my oil rings failed, now i need to rebuild my motor, therefore the tubo has only done about 50kms.
I am selling it for 700 as i need money urgently.
if ur interested pm me asap
