I'm not sure about a fuse, but if you take the headunit out, there is a wire that controls the remote aerial.
Sorry, I don't know what the colour is, look at the headunit installation guide thread. Etiher that, or disconnect the power to the aerial unit from just under it.
NB: signal will not be that good with the aerial inside the car. it's good though if you only listen to cds.
Edited by 97r33gtst-typeM
Thanx guys....
So to get to the ariel motor, i just have to remove the left hand plastic/carpet panel thingy in the boot and reach around and its the box i can feel yeah??
Power cable runs out the bottom?
spot on buddy! u might actually need to remove the whole motor to do it. unless u can find someone with really skinny hands.
When you have a look at the stock head unit aerial connection, you'll see there are actually 2 aerial connections. One for the aerial that goes up/down and one for the aerial that is a series of wires ON your rear window (amongst the deimster wires). If you don't want to the rear aerial to go up and down, simply use the other aerial wire and leave the motorised one disconnected. You should still get a decent radio reception with the "rear window" aerial.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
