The front bar on my GTS4 has the GT-R style lower extension. It has broken once, and now I can't seem to get it to stay attached to the rest of the car - double sided tape, captive screws. Anyone know where I can get a replacement - either just the extension or a whole bar.
https://www.sau.com.au/forums/topic/1050-front-body-kit-for-r32/
Went thru the latest Zoom! and HPI. Found a nice one at www.viper-motorsport.com.au in Adelaide. $500.
Anyone else know of others? I'd prefer the fairly plain type, don't particularly like the aggressive Veilside types.
Thanks, meggala.
They are the Veilside type - VERY aggressive, I'm not in need of that much attention :P edit: oops, that's the one at carmate, the ones at UAS are similar to viper's /edit
The viper motorsport one still impresses me the most. Although it looks like they've removed (or at least cut out) the steel support bar behind it.
Dude, I'm sure you've seen the pics of my car already if not 've attached one more. Why not try a GTR front end second hand? The benefit is they are much more flexible as they are made from plastic not fibreglass. Should be able to source a second hand one from JMS in Adelaide.
I like it as it's not to aggressive, but still looks far better than GTS one.
Just a thought?
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
