Hey all,
Just wondering if the Stagea can SAFELY be run in RWD like the GTR's by removing the ATTESA fuse or something similar. Or is it much harder / impossible to do like removing front drive shafts like the R34 GTR.
And also how many of you have played around with the AWD lock button on the dash. I'm assuming that all it does is lock it into full time AWD. Noticed much difference????
Thanks again
Josh
https://www.sau.com.au/forums/topic/105015-rwd-stagea/
The ATTESSA system in the Stagea S! is like the R33GTR, NOT like the R32GTR. This means it has residual hyrdraulic pressure, so pulling the fuse does nothing.
Do a search, Brad explains what happened to his Stagea when someone tried the R32GTR trick.
The 4wd switch is good for snow and ice and wet grass. Do a search, it was a much discussed subject when we early adoptors got our Stageas 18 months or so back.
:( cheers :(
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1933428
warning, dont believe those first few posts on that thread ska mentions, its gonna damage the clutch packs pulling a fuse, and even bleeding the attessa line does bugger all, except smoke clutch packs on a dyno.
i explained my method in the thread, which i believe is the best/safest way of running rwd, though maybe removing the front driveshaft is easy except u gotta take of the clutch slave cylinder off the gearbox to get it out, or remove the clutch hydraulic line from the slave.
mine was suprisingly grippy running 350rwhp and held better than my previous 2wd car with the rb26 in it (commodore). i think they have alot better suspension setup and only drama was i snapped an axle on the rear diff from launching off a set of lights, as the diff is non-lsd and all the power is going through one wheel only, but i chucked in the gtr lsd and its much better, though i havent used it stuff all since the diff conversion.
in about 3-4 weeks when mines tuned we shall see what power these stageas need to wreck gtr axles/uni joints :P
i just wanna see if the stagea will drift nicely in 4wd and ill try 2wd also.
good luck
Brad
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1933858
do NOT drive around on tarmac with the centre diff lock enabled. you will get wind up in the driveshafts and diffs and will eventually break one,if not the transfer case as well.
use the diff lock on slippery surfaces such as dirt,sand or snow ONLY.
you can most likely fit an ATTESSA control module,which will give you the option of a more rear-biased split. I'll be trying this fairly soon on my car.
Justin...
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1933977
Ok thanks guys. SKA I did try to use the search but it wasn't working. Kept telling me to try again in 30secs because of flood controll or something like that. I tried for ages and gove up posting this thread. I haven't even tried the centre diff lock yet and can't really see when I would.
fergo308 let us know how you go with the ATTESSA control module. I love the AWD but would still like to get it into RWD on occasion.
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1934132
Brad, does the LSD centre drop into the standard diff casing?
I'm still scared to launch my car off the lights in case I break a driveshaft. It doesn't help that my car was fitted with a ceramic button clutch when it was converted.
Regardless, it always bogs down anyway, so harder launches will be required when I wanna run some times.
Oh yeah, and I might be attending the SAU dyno day next month, but it's a 2wd dyno. They've said removing driveshafts will be part of the cost of the run, but now that you mention removing the slave cylinder or hydraulic line throws a new spanner into the works. I'm assuming they know this and it's the same as R33 GT-Rs?
Cheers
Nick T.
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1934865
Cheers
Nick T.
hey nick, yep the gtr diff centre drops str8 in, as its exactly the same housing except the stagea one has the mountings for all the attessa pumps above the diff, which makes it a bolt back in job. im not sure about trying to use stagea axles with the gtr diff as i never tried it personally.
removing the clutch slave cylinder is only 2 bolts and then pull the front shaft off and then bolt the slave back on (dont need to release the clutch fluid or take the line off or nuthin) and away u go. (just move it to the side while u pull the shaft out from under the car)
all up removing the shaft and slave would take 10-15 min max.
hope it helps
Brad
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1935226
the ONLY way to safely make the car RWD is to drop the shaft.
Its honestly not that hard people. 4 bolts and away you go. I was having a look around yesterday.
When i get an LSD i will make the car RWD for some fun, i know ill still have those extra 4wd kg's but we shall see.
https://www.sau.com.au/forums/topic/105015-rwd-stagea/#findComment-1944277
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
