Hi guys, fitting a oil/air seperator (the style with one input and one output, with baffled and steel wool filled internals between the two connections).
One question - It seems easy enough to pick up the PCV line from the top of the engine where both banks join into one, but where do I then plumb back to (the same return hose that was connected to the t-piece?), and where is the PCV valve?
Is it part of the t-piece, or further down near the turbo?
I dont want to stuff up the PCV system, just want to strip as much oil out as I can before it hits the intake.
Thanks
Conrad
If you just tee into the hose that goes from the rocker cover to the inlet pipe before the turbo, you shoud be fine. I think the pcv Vv is at the rear of the rocker cover, with another Vv between the rocker cover and the plenum (front right hand side of the rocker cover) for ventilation whilst not on boost.
If you are having trouble with my expanation, I can put up some pics
Steve
If you could provide piccies thaty would be cool... at the moment I am thinking I pick up the connector which is the t-piece on the right rocker cover, and route through the oil/air seperator and back to where the t-piece connected to (the return line into the manifold).
I was wondering about that other line, the one from the left rocker cover to the manifold - wouldnt it be best to route that through a seperator too??
Thanks for your help
Conrad
With my oil / air seperator, all i did was disconnect the two breathers from each rocker cover, and fitted them into the seperator, then ran a line from the opposite side of the seperator to where the original breather lines go into the intake near the turbo.. I have had it on nearly a year with next to no blow-by in the inlet runner..
The PCV valve should be in the inlet plenum. Follow the hose up from the RH rocker.
If 33s are anything like 32s, then the 2 rockers should be connected by a 'U' of rubber hose. All you need to do is remove the small hose that runs from the LH rocker (passenger side) to the inlet near the turbo, and replace it with the separator and its 2 hoses.
So instead of:
PCV - RH rocker - LH rocker - turbo inlet
you will have:
PCV - RH rocker - LH rocker - separator - turbo inlet
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
