Solid lifters.
There's a pic of the kit on nengun.
They look like regular solid lifters.. Which makes me wonder, would it be possible to drop gtr lifters in there. :S
I would assume not otherwise people would be doing it everywhere.
Im pretty sure u can swap all the gtr stuff over, you just need to find someone upgrading there gtr to 10krpm stuff :)
Think SK mentioned it in the past
  • Replies 64
Posted Images
Solid lifters are solid lifters...
Hydraulics are hydraulics.. They look very much different.
The small pic on the nengun web site or is it greenline?? unsure shows exactly what solid lifters look like.
They basically look like a little helmet.
hey all,
i am building an rb25/30det atm with stock cams, i have heard that the rb30 runs into harmonic issues above 6500, is this true?
i have an rb25det water pump and an rb30e water pump which should i use?
also are you ppl using the rb25det oil cooler.(i have put mine on the rb30det but havnt finished building it yet.)
i am using rb25det oil pump, but tossing up whether to buy new one or not because mine had lowish oil press on the engine it was off and shows slight wear on the teeth.
on the stock skyline guage my oil pump showed;
4-5 at idle when cold
3-4 at 100kmh in 5th
2-3 at idle when warm
my new rb25det(new motor- low km import) oil pressure shows
8+ at idle when cold
~6 at 100kmh in 5th
5 at idle when warm
i used the same oil pressure sender on both engines... so is the old pump stuffed?
This is not fact, but pretty close (i think ;) )
RB26 solid lifters dont drop into RB25. Teh valve stem heights etc are different etc etc so you would need new valves, retainers, lifters, springs etc etc....all that for usign 2nd hand lifters. :rolleyes:
So again dont hold me to that, but a bit of research about 12 months ago had me sh1tty that Nissan gear isnt that univeral :P
There is nothing special about a solid lifter...and mos thead specialists would be able to do the conversion for you using custom lifters. Hell 10 owners get together and buy 240 off him and see what the cost looks like compared to Jap kits
A cheaper way out of a solid lifter conversion would be to use the RB25 neo exhaust buckets. They have a longer foot inside them to take up the distance that a hydraulic lifter normally would. They are made of aluminium and use a shim over setup, toyota 2jz etc shims will fit them to adjust the tappet clearance. They might not be super dear from Nissan and should definately be cheaper than the Tomei etc buckets.
They will work fine with most cams, only with very fast lifting cams you may run into problems with the shim diameter, that would be over 12mm lift though. The shim over setup will be slightly heavier than a shim under but I think the aluminium bucket makes up for the weight so it shouldn't be a problem. It works fine on the NEO.
hey all,
1. i am building an rb25/30det atm with stock cams, i have heard that the rb30 runs into harmonic issues above 6500, is this true?
2. i have an rb25det water pump and an rb30e water pump which should i use?
3. also are you ppl using the rb25det oil cooler.(i have put mine on the rb30det but havnt finished building it yet.)
4. i am using rb25det oil pump, but tossing up whether to buy new one or not because mine had lowish oil press on the engine it was off and shows slight wear on the teeth.
~6 at 100kmh in 5th
5 at idle when warm
Suggestions follow;
1. A properlybalanced RB30 has absolutely no problems to 7,500 rpm
2. The RB25DET water pump
3. Nope, we use external oil coolers, lowers the heat loading on the radiator
4. Use an R33GTR oil pump with a wide flange drive collar (ProEngines have them) fitted to the RB30 crank
:P cheers :(
Ps; don't forget to limit the oil flow to the cylinder head (restrictor) and improve the return to the sump.
Doesn't the 2JZ-GTE run small shims UNDER the buckets? All the 2JZ-GTE heads I have worked on are shim under bucket, the cam lobes working directly on the bucket tops, NOT the shims.
Chris, I have a 2JZGTE here at the moment that has shim over tappets and I did one in December that had the same but we converted it to the shimless buckets from the very late 2JZ/1ZZ engines. There may be one that is shim under but I haven't worked on one that is. The shim over toyota shims are the same diameter and thickness range as the RB25 neo. Have you had the buckets out of the engines you worked on and seem shims or are they shimless buckets, they are pretty common on later Toyotas.
whats the general price on a rb26 head?
only reason i didn't go that way was due to the new exhaust manifold, and inlet plenum i just bought and installed on the RB25..
Prices vary from $1000 upwards, but it was easier for me as i have a RB30 with
GTR sard injectors etc, so all i am changing is exhaust manifold, and will put my
Throttle body on the end of the 26 plenum and change the crank angle sensor
wiring plug. Working out the maths it is lot easier and cheaper in the end with cams than doing the 25 head.
cheers
darren
im also stuck with cam issues, my rb25/30 made 352rwkw@16psi with a modified td07s turb0 its in the shop atm hopin for 400rwkw@20psi, the head has gtr valve springs and gtr cams. the car will be mainly street with the occasional drag and very odd drift..
just wanna know which cams would best suit it and increase the potential of my current setup
ben...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
