Item: Skyline R32 GTR
Item Condition: Very good. Very Clean
Reason for Selling: Business Venture
Price and Payment Conditions: $21500 ONO by cash or bank cheque
Extra Info: Silver in colour in mint condition
Carbon Fibre bonnet
Interior is in VGC, no holes or cig burns, all original with GTR mats
Momo steering wheel and boss kit
Nismo gear knob
Pioneer CD sound system with splits
Nismo dash showing 87,000 km's
Brand new PBR Super Heavy Duty Clutch
HKS twin pod air filters
Mines computer
Greddy speed cut defender
N1 oil pump
N1 water pump
JUN light weight pulley
Steel wheel turbos
Twin 3' into 3.5' HKS front pipes
3.5' HKS exhaust system
Detailed engine bay with polished intercooler pipes and silcone hose
KEI Office Suspension
N1 rear lip spoiler
N1 fluts in front bar
Comes With Current roadworthy and six months rego.
Contact Details: By PM or on MSG board.
Edited by yraceu
https://www.sau.com.au/forums/topic/105067-skyline-r32-gtr/
No I dont have any idea mate, I bought the GTR with everything on it as is. I know that the car drives very very well and has been commented on in high regards by my mechanic at Redline EFI.
Im happy to answer any other questions.
Thanks
https://www.sau.com.au/forums/topic/105067-skyline-r32-gtr/#findComment-1936514
No thanks mate, obviously i will need another car to get around in once i sell this. I only want something around the 5k mark like a SSS pulsar or something as i need the rest of the money to put into my new business that im opening up. Thank you for your offer "samdasurfinman"
https://www.sau.com.au/forums/topic/105067-skyline-r32-gtr/#findComment-1937224
Haven't had her dynoed, dont know the exact power figure, but according to the previous owner it made 296hp at the wheels on 1 bar.
Krizzc: sorry dude would love a Sii R33 but as i have said i need a cheap car to get around in as i have to put my money towards my business. Thank you for the offer mate.
Im keen to sell but not that keen as the shop wont be complete till end of june as they are still being built, so therefore offers will have to be close to the mark as im already loosing money as i have put in a brand new clutch (they are F%#KING expensive) and i payed $22k originally.
https://www.sau.com.au/forums/topic/105067-skyline-r32-gtr/#findComment-1951879
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
