Hey guys,
Just replaced my adjustable cam gear on my car today with a branded one in suspect a distinct sound might go away, guess I was wrong.
Anyhow, the old cam gear I found out was set at -2deg when really it should have been set at -4deg.
What I found when mounting it, was that I had to set my new one to -2deg to mount because at -4deg, those 4 bolts wouldnt line up.
Now basically I want to set it @ -4deg. Its currently on -2deg. Just wondering how would I go about setting this as im pretty sure the belt has to move whilst the adjustment point is loose, in order to set it @ -4deg...
Correct me if im wrong, but what im going to do is turn the harmonic balancer using a rachet with the cam gear adjustment loose till I line it up. Basically once I line it up @ -4deg, i will lock it in.
Is this basically how I set the gear? is tehre an easier way?
Its on a RB25DET by the way
https://www.sau.com.au/forums/topic/105089-adjusting-ex-cam-gear/
i would think that it would be easier to take the cam cover off and move the cam with a spanner to the desired position .. since your only trying to move one thing rather than moving the crank and the inlet cam ..
either a big shifter or a open ended spanner will fit on the hex section on the cam closest to the gear.
I'd just turn the engine over slowly with it loose. Bit more effort to turn it but alot less work than pulling off the cam covers.
Once you do lock it in place, turn the engine over by hand a couple of times to check for any contact between pistons and valves. It shouldn't be a problem with stock or low lift drop in cams but it pays to be paranoid sometimes.
Thanks for the advice guys, ill pop out to the garage soon and give it a shot :cheers:
By the way, would there be much difference in mid range adjusting from -2deg vs -4deg?
Alot of guys on here found better results setting it @ -4deg. Just wanna know what im looking forward too :D
Quick update:
Ive now set it @ -4deg and it seems alot diff as in the car idles alot lumpier and doesnt pull as hard as it used to when it was set to -2deg.
Does this mean I need to go get the car retuned since it was tuned on the map of setting -2deg ?
Feels abit more sluggy in the mid range since changing it to -4deg
Of course they won't line up - the relationship between the teeth and the cam bolts has been dislodged by 2 deg!
Simplest is to remove the rocker cover from the exhaust side and manually adjust the cam.
You're absolutely sure it'as only -4 deg, not a whole tooth or something, because normally 4 deg doesn't have much effect on the idle quality.
And all you are doing by adjusting the cam is moving the power band - you don't necessarily get more power, you just get it at a different rev band.
BTW remeber. 2 degrees on the cam wheel is 4 degrees actual crankshaft revolution. so the people you speak to need to clarify which they are talking about. perhaps that is why the old gear was -2 on the wheel which is actually -4.
In comparing the modified std ex cam gear I had to my greddy one I just put in, the adjustment amount in comparison was 2deg in difference. But do most of the people on the forums set it @ -4deg as in camshaft degree or ex cam gear deg?
blind_elk Im 100% sure its -4deg, not a whole tooth as it idles fine with -2deg. but -4deg its abit lower on idle, and sounds quite lumpy... Also I marked down exactly (using white out) where the marking on the cam gear goes in accordance to the timing belt, and it went back on exactly.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
