Andrew... I too await adsl2, hopefully there's no issues, I suspect there may be though. :S
1283kilobits is roughly 160kb/s. So pretty spot on for a 1.5mbps connection.
Take the speed testers with a pinch of salt...
I would consider Adam or Internode.
Adam if you simply check email + a little web browsing.
Internode if you want an all round excellent service that is always up with awesome international speeds.
Do remember you get what you pay for... You can't go past internode when it comes to their service and quality. Well worth the few extra $$.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938282
I'm with EFtel. Crap service, for example, when we connected there was some stuffup with my friend getting charged twice, and it took three different people to rectify it, but other than that.. good. The best part - 512/128 ADSL, NO limit, NO shaping. 70 bucks a month :) If you're a big downloader, they're one of the few companies that don't shape the bandwidth.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938338
andrew, where is your nearest exhange?
Duc, we're about 2km from the exchange, which is "planned" with internode.
Problem is that Northgate runs off RIMs - we had to wait ages for ADSL to be available at all.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938853
thats disappointing and frustrating to say the least. the 'planned' exchange wouldnt happen to be gepps cross would it? a few of my mates and i are waiting to be ported over to adsl2+ but are being pending on some issues being recified or sorted by telstra.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938917
i was actually thinking of changeing my home telstra cable to adam over the next month.....
same im on cable but thinking ADSL2+ but im right on the max about 4kms from exchange so i need to hear from sum1 @ same distance and wot speeds they get d/ling
Sorry, but access to this feature is restricted to Internode Customers.
Internode 1,500/256 20Gb $59.95 waiting for DSL2+ to be available (hopefully but unlikely - rim hardware issues).
1283 / 110 on the Internode speed test. Seems low.
if ur on a RIM thats ok so long as where the RIM box is there is full copper cable into that Internode can do a Transposition Order and try to get u moved onto a proper copper phone line
Test run on 13/2/2006 @ 12:06 A.M.
Mirror: Bigpond
Test type: Cable
Your connection speed:
kbps: 8592.5
KB/s: 1074.0625
Mbps: 8.39111328125
from here
http://www.ozspeedtest.com/
edit and node server
Test run on 13/2/2006 @ 12:09 A.M.
Mirror: Internode
Test type: Cable
kbps: 9123.4
KB/s: 1140.425
Mbps: 8.9095703125
which if i keep refreshing Bigpond will give me that also i allways get 1173kbps of there file servers
Test run on 13/2/2006 @ 12:12 A.M.
Mirror: Netspace
Test type: Cable
kbps: 9249.9
KB/s: 1156.2375
Mbps: 9.03310546875
Edited by Madaz
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1943757
I'm 4.7km's via road from my exchange.
With regards to obtaining an adsl capable phone line another option is to order an ADSL Essential phone line where they connect up another phone line only if its adsl capable. If not they simply pull out and you get charged nothing.
Hope that makes sense... I've just woken up. :D
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1943857
