I have a turbo kit for sale off an (GTR)RB26 used for under 1000km
It contains the following:
HKS TA45 in NEW condition NO PLAY AT ALL
HKS Cast manifold (getting chrome HBC coated ATM)
HKS 50mm external gate
HKS alloy inlet pipe for 2 afm's
HKS alloy pipe replaces the alloy pipe with "twinturbo" on it and says HKS POWER
Joins the turbo to stock intercooler piping (Gives a factory fit and finish)
2 Stainless Heat sheilds for manifold and turbo will be also included just having them laser cut at the moment
Everything you need except oil feed and dump pipe.
Kit is rated at 650 HP full boost at 4500-4800 on stock internal motor with exhaust and air filter
Perfect kit for a mild but tough street GTR
Item is located in Kellyville Sydney
Price $2400
Lots more pics just look in my gallery
Edited by rx-[7]
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
