Steering Wheel Centre Lock Nut
rs73
 Share
Ok guys,
I want to put on my Momo wheel. So this afternoon,
I managed to get my steering wheels off, piece of cake.
Saw the centre hexagonal locking nut. Sprayed some WD-40 on it, and it wont budge at all..... bugger.... @#$%
I tried using socket 17mm (the largest one I had) but won't fit. I use 3/4" but seems to be just a little bit loose there. Maybe this cause a bit of difficulty turning the socket wrench and the nut won't unlock.
Anyone can help me, whoever done this before, what socket size you use? Metric or Inches system? Is it 18mm or 19mm????
Thx.
Rianto
Gday rs73
I have done this a while ago when I had trouble with my Hicas light coming on. Steering angle sensor was the problem.
I am fairly sure that I used a 3/4 socket. You need a bit of leverage to undo it and I used a Torque wrench with about a 600mm handle.
I am not sure from your comments, but if the socket is stuck on the nut then it certainly is too large.
Once the nut moved I counted the number of turns that it took to come off completely so that it went back on the same.
You will need a steering wheel puller after it has come off. Don't be tempted to bash it with a hammer or something.
Make sure you have a boss kit for our R33 otherwise you will have the Hicas warning light coming on and it will be disabled.
Hope this helps and other guys may be able to confirm socket size etc.
Good luck
El Bee
Thank's guys...
I did use 3/4" but it's a bit loose, probably need to find a metric 19mm socket as 3/4" is 19.05 mm, that .05 mm might make a difference. And of course, I got HICAS boss kit.
I don't have 600mm wrench handle, so might be a good idea to find one, mine is short only like 200mm so I guess won't help me give more torque to the nut. And I'll try spraying more WD40 again, may not be long enough last time...
mine's a lousy socket set bought $27 at bunnings. I dun think it will hold that much, I'm more worried in breaking the lock in the steering mechanism (when you turn off ignition) than the rachet itself. might need someone to hold the steering steady for me.
19mm socket and some muscle. Done it a few times on my car.
To get the wheel off, undo the nut, but not all the way. Sit in the seat with your hands either side of the wheel, and try to pull it off 1 hand at a time, so you are forcefully wiggling and pulling the thing. Thats what I have to do with mine, you cant pull it straight off, have to wiggle it. Leaving the nut on stops you pulling it off and smashing yourself in the face with it or something else unpleasant.
This seems to sound very difficult to do... how did those guys at nissan put these steering wheels on our cars, pound 'em in with a huge sledge hammer???
If after all means I still can't get the centre wheel lock nut off or can't yank off the steering wheels, anyone know a good place in Melbourne who has done R33 with HICAS? I dun wanna some "yea, we can do that - they're all the same" backyard accessories shop around the corner mess up my HICAS sensors...
  • 4 weeks later...
I finally gave up and ran to the local mag & tyre shop. They had this "HUGE" massive 60 or 80 cm long wrench, and angle adjustable. Took them 1 minute to undo the centre nut!
They finished off the installation and cost me a $20 total, nice blokes from sth africa where they came from.
The end result is:
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
