Hello,
I would like to know the answer to this too.
What oil are you using at the moment?
Im pretty sure im using the wrong type, so i want to change it, im using redline light weight in it atm, because i had some left over from when i filled the gearbox, and its an absolute pain in the ass driving it around slow corners.
Ive done a search and the general suggestion is redline mt90 for diff's, but don't know if thats the best option for really tight diffs.
Cheers.
Interesting question, however I have a feeling you can't really do anything about it without taking the diff out and getting a diff specialist to look at it.
My advise is to go to a workshop that specialises in diff's and ask them what you can do. or find someone with a looser 2-way and do a swap.
Some diff's (eg Nismo) allow you to adjust how tight it is, but most diff's don't.
From my experience with different oils in my mech diff, you can't go past Castrol SAF-XA synthetic if you want a more street friendly diff. I found that other LSD oils (including Redline lightweight shockproof) make a tight mech very clunky.
I went through a long saga with mine including getting it pulled down and inspected / reshimmed, and the only thing that made it streetable was the Castrol oil.
Edited by krizza_ca18det
Bl4ck32 runs a nismo 2way adjustable.
I do remember some one suggesting to adjust a little tighter so that it doesn't disengage so easily around corners, obviously resulting in slight tyre squeel but at least there will be very little clunk. He has yet to adjust it, its currently on the loosest setting.
Let us know how the castrol performs. The clunkyness is the only thing putting myself off a mech. lsd.
I must agree with this, before i changed the oil in the diff to redline lightweight, the diff was definetly not as tight, loud and clunky, after i changed over and the oil was run in a little, the diff started to get very loud clunky and tight, with the tyres locking up and chirping while turning corners at intersections. I think i will give this Castrol SAF-XA synthetic a go.
well i took it for a lap arond the block a few times (20 times!) and it seemed to be a lot quieter than whats it was when i first got it, although i didnt do too many tight turns etc.
steve
Hello,
Hows the diff feeling and sounding 2 or so weeks down the track? Also what kind of tool and size did u use to unscrew the bolts? I went to change the oil but to my frustration i didn't have anything that i could use to unscrew them, i will have to go and buy some, and help appreciated.
Cheers!
SNG.
Hello,
Does anyone know if its alright to buy and use some sort of spray to loosen the filler and drain bolts? ive just about destroyed my tool, and bent the handle back and forth a few times and the bolt still refuses to budge, or will it contaminate the oil or loosen the bolt so it may work its way loose later down the track?
Thanks,
SNG.
Also to ask another pretty stupid obvious question, it is counter-clockwise to loosen correct?
Edited by SNG
Hello,
Just to give some feedback, changed the oil over today to the Castrol SAF-XA Synthetic, beautiful stuff, fixed my problems immediately, no more clunking at all nor shudder through the car or chirping of the wheels going thru corners, recommend giving it a shot if your having problems like i did.
SNG.
Hey guys,
Yeah it definitely worked in my case, but as i mentioned earlier above, i incorrectly had redline superlight weight gearbox oil in it so i don't know if that made it worse than it should have and consequently it seems alot better now than what im used to with it.
From memory i *think* it was around 20 bux a bottle of 1 litre roughly from auto one? (You will need about 2 litres) I don't know what type of diff i have, but when i had it on the hoist, when i turned the rear wheel one way, the opposing wheel turns the opposite way, and the diff itself looks aftermarket compared to my previous GTR, i was told that i had an mech diff.
It now almost feels like my last GTR which was stock, but i swear i can still kinda feel it giving resistance very minutely when going around corners.
I just wanted to give some feedback from my personal experience regarding this oil, it may work in your case, it may not.
Cheers!
SNG.
Chrylser make a rear diff oil additive for they call their Jeep Cherokee range, here in the UK (4wd 4x4). The plate type rear diff is poor in these, and tends to clunk and chatter (as well as the CWP wears out for fun...). Some people get really up tight about it and Chryler, like GM did in the 70's with the Corvette, came out with a friction additive for the diff oil. If you bung 2 bottles of it in a plate type diff it will often stop chattering and ratcheting, but a lot depends on the preload it's set to, and the style of the friction plates. Worth a go, it's not expensive over here, at least.
  • 1 month later...
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
