Hello,
I would like to know the answer to this too.
What oil are you using at the moment?
Im pretty sure im using the wrong type, so i want to change it, im using redline light weight in it atm, because i had some left over from when i filled the gearbox, and its an absolute pain in the ass driving it around slow corners.
Ive done a search and the general suggestion is redline mt90 for diff's, but don't know if thats the best option for really tight diffs.
Cheers.
Interesting question, however I have a feeling you can't really do anything about it without taking the diff out and getting a diff specialist to look at it.
My advise is to go to a workshop that specialises in diff's and ask them what you can do. or find someone with a looser 2-way and do a swap.
Some diff's (eg Nismo) allow you to adjust how tight it is, but most diff's don't.
From my experience with different oils in my mech diff, you can't go past Castrol SAF-XA synthetic if you want a more street friendly diff. I found that other LSD oils (including Redline lightweight shockproof) make a tight mech very clunky.
I went through a long saga with mine including getting it pulled down and inspected / reshimmed, and the only thing that made it streetable was the Castrol oil.
Edited by krizza_ca18det
Bl4ck32 runs a nismo 2way adjustable.
I do remember some one suggesting to adjust a little tighter so that it doesn't disengage so easily around corners, obviously resulting in slight tyre squeel but at least there will be very little clunk. He has yet to adjust it, its currently on the loosest setting.
Let us know how the castrol performs. The clunkyness is the only thing putting myself off a mech. lsd.
I must agree with this, before i changed the oil in the diff to redline lightweight, the diff was definetly not as tight, loud and clunky, after i changed over and the oil was run in a little, the diff started to get very loud clunky and tight, with the tyres locking up and chirping while turning corners at intersections. I think i will give this Castrol SAF-XA synthetic a go.
well i took it for a lap arond the block a few times (20 times!) and it seemed to be a lot quieter than whats it was when i first got it, although i didnt do too many tight turns etc.
steve
Hello,
Hows the diff feeling and sounding 2 or so weeks down the track? Also what kind of tool and size did u use to unscrew the bolts? I went to change the oil but to my frustration i didn't have anything that i could use to unscrew them, i will have to go and buy some, and help appreciated.
Cheers!
SNG.
Hello,
Does anyone know if its alright to buy and use some sort of spray to loosen the filler and drain bolts? ive just about destroyed my tool, and bent the handle back and forth a few times and the bolt still refuses to budge, or will it contaminate the oil or loosen the bolt so it may work its way loose later down the track?
Thanks,
SNG.
Also to ask another pretty stupid obvious question, it is counter-clockwise to loosen correct?
Edited by SNG
Hello,
Just to give some feedback, changed the oil over today to the Castrol SAF-XA Synthetic, beautiful stuff, fixed my problems immediately, no more clunking at all nor shudder through the car or chirping of the wheels going thru corners, recommend giving it a shot if your having problems like i did.
SNG.
Hey guys,
Yeah it definitely worked in my case, but as i mentioned earlier above, i incorrectly had redline superlight weight gearbox oil in it so i don't know if that made it worse than it should have and consequently it seems alot better now than what im used to with it.
From memory i *think* it was around 20 bux a bottle of 1 litre roughly from auto one? (You will need about 2 litres) I don't know what type of diff i have, but when i had it on the hoist, when i turned the rear wheel one way, the opposing wheel turns the opposite way, and the diff itself looks aftermarket compared to my previous GTR, i was told that i had an mech diff.
It now almost feels like my last GTR which was stock, but i swear i can still kinda feel it giving resistance very minutely when going around corners.
I just wanted to give some feedback from my personal experience regarding this oil, it may work in your case, it may not.
Cheers!
SNG.
Chrylser make a rear diff oil additive for they call their Jeep Cherokee range, here in the UK (4wd 4x4). The plate type rear diff is poor in these, and tends to clunk and chatter (as well as the CWP wears out for fun...). Some people get really up tight about it and Chryler, like GM did in the 70's with the Corvette, came out with a friction additive for the diff oil. If you bung 2 bottles of it in a plate type diff it will often stop chattering and ratcheting, but a lot depends on the preload it's set to, and the style of the friction plates. Worth a go, it's not expensive over here, at least.
  • 1 month later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
