It is time to sell my R33 GTST
Have bought a Stagea
1995 M-spec series 1.5
Manual
Full respray in Ford Blueprint XR6, includes engine bay, top of motor and brake calipers
Full DP Sports bodykit
Rebuilt hiflow 400hp ball bearing turbo runnings stock boost
3 Dump pipe and Cat
3 1/2 inch S/S Jap cat back exhaust
Apexi pod and custom cold air box
Zeal alloy body coilovers
Dewalt evolution 17x9 and 17x8 3 peice gold centres polished rim
235/45/17 on front 50%
255/45/17 rear 80%
Pipeapples
Nismo short shift, clear side indicators, carbon pillar's, gear knob
Alpine CD headunit, Focal splits to front, Jaycar rear speakers, Rockford amp
96,000km
Registered in Queensland 7/2006
RWC upon sale
1 owner in Australia last 2 years
Arrived from Japan with 61,000 with log books, stock as a rock
All mods would cost approx $18000 to replace new
Sold
https://www.sau.com.au/forums/topic/105150-r33-gtst-m-spec-ford-blueprint/
  • 1 month later...
Camera is in getting repaired at the moment
Not sure when I will get it back 1-2 weeks maybe
Give me a call if you are keen to discuss
Price nego.
Thanks
  • 4 weeks later...
looks nice mate, pitty its stock as a rock..
Would only need $2000 for a Power fc, fmic and bleed valve and you should see upto 220rwkw with that turbo
What do you expect for $15k + ???
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
