it seems like dynodynamics on shootoutmode is the popular choice for a dyno readout but ive heard recently that autosalon changed their dyno to a mainline dyno . which one is more accurate?
two different dyno's (mainline and dyno dynamics) in the same city (around 5 klms apart), two days apart with similar barometric conditions. read within less than 1% of each other. With the same vehicle.
Not bad eh!....pretty acurate
and yeah, just on that... the Cabin group have been using mainline dynos since 2002/3.
So its far from "recent" news
Where?..which dynos? Anytime I have seen the same car go on a dynolog and then a dynamics, the dynamics always reads about 10-15% higher.
Croydons...then Autosalon....and it was Stacey's car...so i should know.
Edited by DiRTgarage
I didn't say you didn't...but I think Cabin must have a 'special' version of the Dynolog software.
I know of a wrx that made 20% more power on CRD's dyno in the afternoon than it made on a Dynolog in the morning. There were no changes in between. Had the same tank of juice and all.
All the other dynologs I've seen read very similarly (comparing the same cars on different days)
did you record the temps on that day?
you said morning and arvo... so my bet there could have been a reasonable temp difference.
end of the day, does it really matter? anyone can can get any figure if you need too
Yep...it was slightly warmer in Syd than the gong...only a degree or 2.
Yep..I agree
Well how does this grab ya...Carlos from Millenium Motorsports ran 599kw at Queensland 2 days before Autosalon on his Mainline dyno...and at the same boost levels ran 601kw on Autosalon's dyno.....he must have the "special" software too!
Mainline dyno's even run the same no matter if its 2WD or 4WD...we proved it in front of hundreds of people at Final Battle...there was 1kw difference between the runs.
I think what Mik is trying to say is Croydon's dyno is happy...if its so happy i should be rolling almost 520AWKW......i think im gonna have a word to Jim about my deflated power figures.
I Have seen IDENTICAL results on two different dynologs equate to 40awkw more on two different dynodynamics dynos in an unchanged trim/tune. Just my experience.
highly experienced acredited operators should not have such a discrepancy...as essentially the dyno's use similar hardware.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
