that means your tyres need replacing.
i ran 330rwkw and had little traction issues using street 225's.
skated a tad @ the top end of each gear. Otherwise in my book it was nothing.
I've seen poorly setup stock R33's get more wheelspin.
all in suspension and tyres.
As for your question about torque... i doubt many here have had thier motor on an engine dyno to be able to accurately answer that.
Dynos are a tuning tool... worse if you try using the torque figures
What does the R31 have leaf springs??? LOL
  • Replies 47
good post
im about 200rwkw, and its probably too much for just a street car
just a quick blip and you are pretty much over the speed limit
theres not many roads around where u can enjoy the power without exceeding the speed limit
id love to make more power if i hit the track, but as my line is our daily driver and it needs to be on the road, it probably will never happen
i wont be powering her up anymore i dont think
This is why I went the 3ltr... Improve that 0-speed limit acceleration by minimising lag and increasing low engine speed torque.
Idling up off the line the 3ltr really does haul arse with the skylines low diff ratio's.
Idling and simply popping the clutch with wot will have it accelerating off the line quicker than the usual LS1 V8, the V8's tend to bog down and lag a little before reving up.
LS2's its around par on as they do seem to ave quite a bit more of a lunge at low rpm.
My uncle has a 250i 6speed LS1 that really does feel rather gutless at low rpm compared to mine.
a track car obviously means a high revving 2.7 -> 3.0 with large twins ?
Even then, on slower tracks, it will most likely get munched.
i just meant a car that is only used on the track.
for a perfect street car i think u will need round 280-300rwkw. i have 260 at the moment and it feels a little slow after a while. definately going to upgrade to something bigger
You guys are all crazy...:(
Ok, i owuld love a GT3 Porka as a street car. It would be lucky to have 250kws at the wheels!
Even with 200rwkws you cant even rev out 3rd gear...If its a street car, the more power you have the sooner you will find yourself in a world of trouble ...which is no fun.
If you use your car for somethin other thenA-B day to day driving, lol the more power the better :P
my vl had rb25, t70, plenum, microtech, fuel system, gate etc etc....
270rwkw on 13psi in a 1300kg car was scary, but it still wasnt enough ;)
enough to light up the rears at over 100kmph but still not enough.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
