Power....when Do You Think Its Enough?
He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
By SeanR32GtSt 路 Posted
Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now. IMG_7261.mov -
By DraftySquash 路 Posted
Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better! Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 馃ぃ (image attached for reference) I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar. -
By pacman_1219 路 Posted
Not sure what you mean by electronic speedo drive. Speedo reads fine up to 180 yes.
