Holden VK Calais
1984
"mistle toe" Green over Silver - rare factory colour
5.0Lt V8
3sp Trimatic Auto
light green interior
digital dash
power steering
electric windows / mirrors / aerial
Polished original Calais alloys
lowered
Reg till 12 feb 2007
Car is in OK condition, interior in great condition.
Its not without its problems though:
different coloured bonnet ( I have the paint for it)
bit of rust at the bottom of the C pillar
auto starting to slip slightly between 1st an 2nd
diff noisy (but reliable)
A/C not working
Cruise control not working
a few lifters starting to be noisey
the car has been my reliable daily driver in the above condtion for over 2 years now.
Car as is $2500
Car with above fixed (apart from a/c & cruise) and R.w.c. $4500
Contact Berin
[email protected]
0417 546 384
https://www.sau.com.au/forums/topic/105195-holden-vk-calais-50lt/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
