ok i was giving my R32 GTR a bit of a flog (as you do)
just come out of one corner and heading to the next and was about 5k in 3rd
then POP (a jolt of deceleration) so as you do you go into What The F@%K mode
then after that i find it still idles the same and drives the same until.....
about 3k (where boost usually is) and it begins to sorta cough and pretty much wont rev any higher
i am yet to pull off the exhuast to look for remains of turbo in cat (as it happened JUST now)
just want to make sure that it sounds like my turbo and i havent done any Major damage
and i have done a search and couldnt find anything is anyone else finding the search not really doing it job anymore?
Well Damn!!! ....but it looks like its could be time for some GT-SS's
Thanks
RellikZephyr
https://www.sau.com.au/forums/topic/105201-did-i-blow-my-turbo/
pop and then coughing and spluttering, are you sure the plugs are on the air flow meters firmly, done that one before, car went into safety mode over a speed bump when the plug fell out, wouldnt rev over 3k lol...
having said that, i have also blown 2 turbos, tap the cat and see if there is a rattle like noise, also mine backfiered heaps when i blew the seal in one of the turbos, then no boost when i blew the wheel off the other one :P
Edited by oRiCLe
you guys are absolute CHAMPIONS!!
i didnt even think off intercooler hoses
and it was an intercooler hose passenger side on cooler to be precise
Thanks a bunch you guys i was shittin!!
Champions Thanks again
RellikZephyr
I would check your AFM too. When I had a VL (dont hold it against me :) ) The same thing happened. It made a really load pop (i found out later it was just a huge backfire) and after that point the car would get to 2000rpm and not go any higher. Changed the air flow meter and it was good as gold.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
