ok i was giving my R32 GTR a bit of a flog (as you do)
just come out of one corner and heading to the next and was about 5k in 3rd
then POP (a jolt of deceleration) so as you do you go into What The F@%K mode
then after that i find it still idles the same and drives the same until.....
about 3k (where boost usually is) and it begins to sorta cough and pretty much wont rev any higher
i am yet to pull off the exhuast to look for remains of turbo in cat (as it happened JUST now)
just want to make sure that it sounds like my turbo and i havent done any Major damage
and i have done a search and couldnt find anything is anyone else finding the search not really doing it job anymore?
Well Damn!!! ....but it looks like its could be time for some GT-SS's
Thanks
RellikZephyr
https://www.sau.com.au/forums/topic/105201-did-i-blow-my-turbo/
pop and then coughing and spluttering, are you sure the plugs are on the air flow meters firmly, done that one before, car went into safety mode over a speed bump when the plug fell out, wouldnt rev over 3k lol...
having said that, i have also blown 2 turbos, tap the cat and see if there is a rattle like noise, also mine backfiered heaps when i blew the seal in one of the turbos, then no boost when i blew the wheel off the other one :P
Edited by oRiCLe
you guys are absolute CHAMPIONS!!
i didnt even think off intercooler hoses
and it was an intercooler hose passenger side on cooler to be precise
Thanks a bunch you guys i was shittin!!
Champions Thanks again
RellikZephyr
I would check your AFM too. When I had a VL (dont hold it against me :) ) The same thing happened. It made a really load pop (i found out later it was just a huge backfire) and after that point the car would get to 2000rpm and not go any higher. Changed the air flow meter and it was good as gold.
