  • Replies 419
Posted Images
To be fair to the guys who have already paid, like...jazree, slimjim, Mr Cali, and hanyou. ill do this batch in two lots of five....so i only need 1 more name to make up 1/2 batch and send out....then ill start taking names for the final five.
p.s. the final five could be the last batch of these made up....im over it.
Edited by DiRTgarage
I'll pay the money into the account 2moro lunch time!
Been busy with uni, so sorry about the delay!
So that'd make me the last of the 5.
Ali.
Edited by IOWNU
  IOWNU said:
Hey!
Any news....rough approximation if possible?
Thanks.
Ali.
6 parcels sent out today...yes you are one of them
parcels have been sent to the following people
IOWNU
jazree
Mr Cali
slimjim
J-Boy
hanyou
  Cro_boy_Mario said:
can this be used on the r33 gts4???
and can i switch from 4wd-rwd-4wd without turning off the car?
sorry only r32's compatable
and yes switching can be done without switching off ignition
Last batch...names in and paid are as follows...
justinfox
neshgtr
please pm if you are interested as there are only 4 of these left (i did say batches of five but i have six this time)
  IOWNU said:
Hey,
I recieved mine earlier this week as well.
Very happy with the product!
Thanks for your efforts DiRTgarage.
Thanks guys (add to trader rating if you like)
ive just realised i forgot to add the cable ties to the bags...sorry :/
Trader rating added. I wondered where the ties were haha no biggie :/
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
