  • Replies 419
Posted Images
ok new batch started
1/Jolinator
2/ttomie
3/Nismo32R
4/MikeyGTRmike
5/gun32gtr
6/jonn
7/daemon667
8/Cam
9/gtrboosting
10/
one spot left if someone wants it...must be in by end of the weekend
no worries here..cant wait to get her in....
a box of 10 "Narva" switches arrived just as i was leaving for sydney this afternoon. Ill finish them off while im away racing this weekend and pop them in the post 1st thing monday.
i could have skimped on the quality a little and bought cheap shit switch mech's but this is not my go. Narva is great quality stuff, and almost everyone who has bought one has commented on the high quality.
So with this switch you can change from 2WD to 4WD without turning the car off?, On an R32 GTR that is, if so put me down for one on the next batch and send me your account details. Thanks
yes...no need to reset ATTESSA ecu by switching car off. R32 GTR and GTS-4 only.
you can have the final one in this batch if you like...ill pm you the account details.
looms sent to...
jolinator
ttomie
gun32gtr
jonn
Cam
gtrboosting
still waiting on deposits from...
Nismo32R
MikeyGTRmike
daemon667
BlackR32
IDO 11S R32
thanks
looms sent to...
jolinator
ttomie
gun32gtr
jonn
Cam
gtrboosting
Nismo32R
MikeyGTRmike
daemon667
BlackR32
IDO 11S R32
thanks
errr??? i already transfered $50 to ur account long time ago
i even PM you the transfer details
plz check
plz check
hi Paul
i just sent u another PM with transfer details which was done on the "3rd of OCT"
plz check and let me know whats happening
thx
hi Paul....
can u plz let me know if u have received my money which was transferred to u on the 3rd of oct plz
thank you
recieved and loom sent
Guest
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
