if they will fit C210, then i'm very interested, but wont be wanting them for a few weeks, still sorting out finances after christmas...
Jason,
Do you know the diference between the 2 bars, do you have some measurements of the C210 bar, overall, bolt mount spacings etc.
Dennis
Jason,
Dennis
I'll measure them up after work today
rose joints are not street legal, and will also put you out of any realistic category if you run a hillclimb or sprint event - technically, you'll have to run as a sport sedan!
you can have your standard castor rods made adjustable by machining them down so you can extend the thread, and them lock them up with a nut on either side of the bush. last time I had a set of standard castor rods made adjustable it cost about $80 including remove and refit! but that was several years ago
they are shiney though :P
I'm using the SWR type with Nolathane bushes and works well , my experience with spherical joints on road cars has not been good . No compliance and plenty of road wheel noise and vibration transmitted into the shell/cabin area . Rose joints are not a high mileage item which is not an issue with dedicated race cars .
I chose not to modify the std rods because its debatable if the steel is up to it . The SWR rods are made from 60T steel and larger than the std ones . They come with the tube that the bushes locate over (+ nylock nuts) and std Nolathane bushes can stretch over them with no probs . Fit set forget .
Cheers A .
the standard ones are up to it. You have to remember that Stew is a died in the wool rally man. The top guys always over engineer things to last in that harsh environment. If you don't finish, you can't win. I wouldn't rally on them either, but anything short of that, they should be fine.
I did it on my Datsun 1200 race car's castor rods, which are the spindliest looking things in the world, and it was subject to years of kerb hopping, being airborne on road rallies, not to mention a few excursions... All with the added load of a big arse L20 on top of it. And then there's the incident with sliding into a square edge gutter on one special stage of a road rally, which sent me airborne, and spun me 1.5 times, bending the chassis and strut tower, breaking wheel bearing races and cracking rims... the spindly castor rods survived just fine.
The only reason a modded one would be any weaker than the unmodified factory part is due to the slightly longer threaded section, but a castor rod really doesn't handle any shear or twisting forces that would make it an issue - it takes tension loads, and the strength in that direction is unchanged. All I would recommend is not leaving a square step at the end of the extended thread where it steps back up to the diametre of the arm, as it could be a stress riser.
Anyway, I'd do it again in a flash in total confidence. I'm not one to cut corners where safety is an issue, but I'm also not into adding weight or spending money where it isn't necessary.
The SWR arms are definitely a good product and well worth the money, but I think it's overkill for my application.
ive broken to many heim joints /rose joints of various brands and makes including aircraft quaility racing speedway there would be no way i would ever trust one on a road car . apart from the insurence side of things as well
Good post hrd-hr30.
Funny that this subject came up - I pick up my modded rods tomorrow. I am going to go rallying on them (next weekend), so we shall see how it goes. I'll be bringing some spares just in case. :P I'll keep the SWR ones in mind for the near future.
Done already. Good point to mention though.
Thanks Harry,
You sorted me out yet again, as I didn't consider that possibility, that I could have gone right away from anything other than modified production.
I might just go with the SWR ones as I was originally planning and using 1600 daddo polyurethane bushes.
Guess the whole idea is going down the toilet now guys, but if someone really wants them, I will price them up and let all know.
Cheers,
Dennis
sorry mate. rules always spoil the fun. I have the same problem with my GTR if that's any consolation. it came with rose jointed castor rods... I can get away with it at my local hillclimb because they have a separate class for AWD turbo cars that isn't a recognised category and has no published rules! ;) but for anything else, I'm sport sedan, just because of 2 lousy rose joints... grrr :D
Just an update post rally. The modded radius rods worked a treat. I didn't bend or break one, so that is a good thing. The suspension copped a few big hits - biggest ones being a 4th gear 5000 rev downhill into a gully and onto a wooden bridge then up the other side. My stomach is still in my left butt-cheek! :) It had a good go of punching the shock through the strut top, tearing the rubber in a nice semi-circle.
After they were installed (and prior to the rally of couse), I went to my friendly steering place and measured it all up. My suspension geometry is all over the place! At least it explains the funky handling...
FRONT
Caster: 6 degrees
Static camber: +0.5 degrees (yes, plus)
Toe: Set to 0
REAR
Camber: +1.5 degrees
Toe: 2.8mm out (L) 0.8mm in ®
Interestingly, when the wheel is turned, the front camber changes from +0.5 to -0.5. I honestly thought that it would change the camber by more than that.
Obviously my car is set up very differently to how a street car would be set up. For example, I have had to adjust the ride height (home-made adjustable struts) so that there is 170mm of ground clearance under the sump shield. Thus, the car sits higher than standard, and the front control arms hang down more than usual (adding to the positive static camber). Strut tops are 180B items (factory Skyline ones bend too easily). Rear sits slightly higher as well. Personally, I would love to run the car lower, but the low-slung front crossmember makes ground clearance an issue.
Next thing on the list is to sort out the suspension settings a bit more. Custom strut tops are now on the cards to try and get some neg into the front, and I now think that the left trailing arm may be bent, so I'll replace that as well to try and get back some toe-in on the rear. Brakes are also an issue (I can't get enough rear bias).
Anyway, just thought I'd keep you updated...
Cheers,
Matt
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
